Sky InsuranceAH Fabrications
Results 1 to 39 of 39
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    Rolling road power query
    Hi all. Had my 2002 S3 put on the rollers for a stage 2 REVO. i currently have REVO2 with 3" downpipe/cat, FMIC, TIP, 007p, panel filter and the car only made 256bhp and 289lbs/ft.
    Now from my understanding, correct me if im wrong, the S3 is made to run FWD on the rollers as the haldex tries to switch the power front to rear so it cant be run fully 4WD. So only a certainamount of the power is being sent to the front wheels, thus making less power than it should.
    Is this correct?
    I know its not all about how much bhp you have, its how it drives, buti would like to know what power its putting out.
    Anyone have any comments to make?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Nope, that's not correct mate I'm afraid. It will make the same power either on 2WD or 4WD. Mechanical drag remains the same, and the power is simply delivered through the front wheels.
    In my personal opinion, that is around the correct figures for a REVO Stage 2, maybe a little low - but not much, and sadly their claims are just a load of rubbish. Mine is equivelent REVO Stage 2 with bags more timing than a Stage 2 map, and I only made 3 more BHP than you.
    EDIT: Good torque though.
    Homer Simpson
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    I had on a "Dyno Dynamics" ment to be one of the best rolling roads around with the spec below... 250Bhp and 285Ftb
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by indiemike View Post
    Yep, I think that's a realistic figure to be honest. It's not a 'happy dyno'.
    Homer Simpson
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    That's shocking! Revo quoted me 270-275bhp daily and then high boost on my SPS 3 control would be 280-285bhp. That was for a stage 2 Revo and using the SPS 3 i have sitting at home.
    I'm running at Stage 1 Superchips at the mo which was already on the car and with a few mods i've done i'm getting 258bhp with 244 lbs/ft. My torque seems really low though compared to others!?
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    The car used to be fast enough and cant really argue with the figures.. Do miss that power now tho
    Now : Cupra R 225
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Quote Originally Posted by DJ_Troopa View Post
    Yea used the SPS3 system... Boost cranked up to "9"
    Now : Cupra R 225
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    My map is also on high boost at 9 but my timing is at approx level 11 (I know that doesn't exist - extra timing added) and still making around 260 ish. My turbo not making requested boost though as I suspect actuator has gone soft.
    Using an MBC to get the requested boost has brought BHP up and Torque up miles.
    Homer Simpson
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    What does timing and boost mean on the SPS control?
    I've had a fully rebuilt turbo by CR with upgraded thrust bearings so hopefully the turbo will stay consistent when the time comes for Revo stage 2!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Adjusts timing and boost level on the map (as they are adjustable). Standard REVO map is level 6 I believe and then max is 9 on both timing and boost.
    Bear in mind, too much timing is BAD! Big timing pull figures if adjusted too much.
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    What they quote and whats actually produce are further away than you would think.... let me draw your attention to a recent test of 'quoted' figures vs actual...
    NEW DYNO for Badger5 - Premesis move deferred - Page 14 - SEAT Cupra.net - SEAT Forum
    The thing to note is the before and after figures...
    <tuffty/>
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    That's good stuff there! Madness on what they quote and what you actually get! Goodness me, i won't get my hopes up too much for a Revo stage 2 then lol.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    was it run in 2wd or 4wd?
    at the wheel figures were?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,175
    do you know your max airflow?
    www.badger5.biz
    bill@badger5.co.uk
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    i cant belive im only up 35hp and 80lbs/ft with revo2 from std and ive spent roughly 1200 to get there. crikey.
    But to be honest it feels soo much quicker than 255bhp on the road
    RIP S3dave
    May 2004
    nr Glos
    7,175
    on my dyno on a std 225 LCR I saw between 223-230bhp and 198lbft depending on how hot it was
    a revo stage 1 s3 with its sps maxed to 9's plus some more timing on top, 259bhp/238lbft
    a hybrid K03/4 with water meth 273bhp/280lbft
    a TDi 150 Leon, 175bhp/260lbft before remap and 205bhp/322lbft after
    My rollers are obviously of the grumpy nature like me
    www.badger5.biz
    bill@badger5.co.uk
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Silly question Bill, max air flow? As in g/s?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    ....My rollers are obviously of the grumpy nature like me
    <tuffty/>
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    947
    You grumpy,no mate,will have bring mine down for some work and a spin up,would be good to have a real figure instead of amd happy figs,dyno lottery mate,lol.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by ANDYTQ View Post
    some nice mods going on there andy...
    RIP S3dave
    May 2004
    nr Glos
    7,175
    aye thats the one g/s mass air flow, block 002 or 003 etc
    www.badger5.biz
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,175
    aye no worries.. 2 roundabouts off j13/m5
    www.badger5.biz
    bill@badger5.co.uk
    colicabcadam
    Quote Originally Posted by gez View Post
    Is this correct?
    bhp sells cars, a flat smooth torque line wins races.
    change your injectors, they're 8 years old, you'll prob get another 2% increase.
    not sure why people are so bothered about figures, who cares!!
    audi quote 225bhp at the CRANK, not the wheels, there's a huge difference, your car prob has around 285 bhp at the crank, around 15% is lost through the transmission and drive shaft system.
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    Im pretty sure my dyno graph says engine power not wheel power. Surly not 289lbs at the wheels?!?!
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Figures are fine. 80lbs increase is alot. Thats why remaps feel so good.
    2003 Audi S3 + Go faster bits
    colicabcadam
    if the wheels were on a rolling road, then the power was calculated from the wheels........... unless they took the whole engine out and connected the crank to some sort of machine when you was not watching lol.
    289lbs @ 4,000 rpm = 220 bhp, 289lbs @ 5,000 rpm = 275bhp
    where did you get this torque figure from, unless your engine is dropping its torque curve dramitcally once it reaches 4,000 rpm, there is something drastically wrong with your figures
    are you sure it's not 289 bhp and 256lb - that would make more sense
  28. #27
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    I think you may have misinterpreted gez's post. I assume when he says engine power, he means flywheel power and when he refers to wheel power I assume he means bhp at the wheel, ie flywheel power minus transmission loses.
    Im a little unsure as to what you mean with the "289lbs @ 4,000 rpm = 220 bhp, 289lbs @ 5,000 rpm = 275bhp". Surely you would need a graph to analysis to come up with such info. 220 bhp @ 4000 rpm then 275 bhp @ 5000 rpm, thats a pretty steep gradient is it not.
    Personally I think a strong running stage 2 S3 should make roughly 270 - 280 bhp and 280 - 300 ft/lbs.
    Nathan
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
  29. #28
    RIP S3dave
    May 2004
    nr Glos
    7,175
    got the plot they gave you?
    should have at the wheels power figures and torque, plus coastdown/rolling losses probably (unless its a Dyno dynamics and it just adds a figure to the at the wheel figures)
    www.badger5.biz
    bill@badger5.co.uk
  30. #29
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by colicabcadam View Post
    unless you know the rpms these figures were achieved you can only be guessing the numbers..
    285bhp would want around 228g/s or more of g/s airflow as another guide/comparison
    www.badger5.biz
    bill@badger5.co.uk
  31. #30
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    I shall scan the graph on here today
  32. #31
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Ah i thought so! Liquid gauge tells me 208 g/s. That's with a BMC kit by the way. I'll be calling you soon hopefully end of the week to get a Jetex
  33. #32
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Running 4wd @ fly
    Cant remember the wheel figures
    Now : Cupra R 225
  34. #33
    colicabcadam
    Quote Originally Posted by S3 Nattie View Post
    Nathan
    remember, bhp is calculated by torque and rpm, the above statement was a theory if he had a flat torque curve, that would be the bhp at those revs. therefore, his torque curve must dramatically drop at around 4,500 rpm to get only a max 256bhp
    let's say he has 256bhp @ 5,800 rpm, at this point, his engine would be creating 220lbs torque, therefor that's a big jump down from 280lbs! i'd say his peak torque figure was gained before 4500 rpm but then after this his torque figures dropped quite quickly
    i'd like to see the print out to see if i am correct lol
  35. #34
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Calc for those who dont know:
    bhp = (torque in lbft x rpm ) / 5252
    some sample graphs off mine..
    right click save_as
    http://badger-5.com/bin/Dyno/dyno-s3...-lcrgt30-1.jpg
    www.badger5.biz
    bill@badger5.co.uk
  36. #35
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Running 4wd @ fly
    dyno dynamics rollers dont measure coastdowns, they just ad a number/% onto the atw figure, with the figure relating to mode used 2wd/4wd and transmission option chosen
    www.badger5.biz
    bill@badger5.co.uk
  37. #36
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Alright Bill, my air flow is 208 g/s according to my Liquid Gauge as you requested before. That's with a BMC but i'm coming to you soon for a huge Jetex filter!
  38. #37
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    Here is the dyno graph for my revo2 map.
    the RED line is my previous custom map and the PINK line is the "unadapted" REVO2 map.
  39. #38
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    This is why I LOL at my "alledged" BHP figures on a stage 1 remap....
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
  40. #39
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    so does my graph seen about right? am i low on BHP but high on torque.
    Im fitting an MBC this week to try and get the boost to hold longer in the revs and will take it back to AMD to put it on the rollers to check the fueling.
