Theres more knowledge in these parts about big turbos, hence the question over here!
Not much in the way of big turbo info in B5 land, bar the odd garrett conversion, and seen it was more about the general end result rather than specific application info then i figured here would be fine!
As for the manifold, your right, its no use, but i can always adapt a KKK manifold or whatever to make it fit. This is all very much in the vapour build/planning stages at the moment, i want to sort the suspension and quite a few other bits on the car before looking at more power.
I hear what your saying about comparing dyno charts, wasnt really thinking about how ramp rate etc would affect how quick the power/boost would build.
I guess what i'm trying to get my head round is how nice its going to be to drive normally. Obviously the power will be there at the top when your going for it, and unlike the k04 it'll pull much harder right up to the redline, which is ideal, but i wouldnt want to ruin the cars day to day drivability.
You say your off boost when tootling around, but i disagree. Maybe when just trundling along at a constant 30mph, but not when your doing any sort of accelleration, even if its just pulling out onto a roundabout or out of a side road, or calmly building speed after joining a faster road etc. The difference between my remapped ecu and stock one was noticable even from the passenger seat when driving around normally. You might not be at full throttle, but the engines under enough load to be on boost and the difference is noticable.
We drove the car around for a month or two with a broken wastegate penny, and it was dog slow, even around town etc. I wouldnt like it to be like that before the turbo spools up and all hell breaks loose at 3500rpm or whatever.
The dyno plots seem to suggest it builds slowly but progressively, rather that being completely dead then having a wall of torque as the turbo spools hard at 4k which you often see on really big turbos. Is that how it feels on the road?
I guess the better question would be, how does the car feel when driving around normally? Do you notice its worse than a stock engine, or is it powerful enough not to cause a problem?
Cheeers
