Results 1 to 20 of 20
    Jul 2009
    Saltburn by Sea
    67
    Boot jammed shut! Help Please!
    I can't get the boot open on my 97 A3, it opened fine yesterday and I've never had a problem, I can here the lock opening and closing but it won't release.
    Help!
    Jul 2010
    bristol
    647
    push on it really hard to make sure its PROPERLY closed, should able to open it then! i had a similar thing happen on my old a3
    Jul 2009
    Saltburn by Sea
    67
    Done that loads, it won't budge.
    Jul 2009
    Saltburn by Sea
    67
    Bumped for the weekday crew, I'm still getting nowhere.
    Aug 2007
    199
    Do you have an 'open boot' button on your key fob?
    Jul 2009
    Saltburn by Sea
    67
    No
    Aug 2007
    199
    Are you using the remote to unlock it or the physical key?
    Jul 2009
    Saltburn by Sea
    67
    Tried both, you can here it unlocking through the central locking but when you squeeze the paddles either side of the lock nothing happens.
    Aug 2007
    199
    Ok. Have you tried applying some weight to the boot lid (careful where you push down) while trying to open it?
    Jul 2009
    Saltburn by Sea
    67
    Yep, had me and my dad pressing down, no luck.
    Aug 2007
    199
    I am not sure if its possible to get to the boot internals from inside the car with the lid shut. Have you looked for access to the lock this way?
    Jul 2009
    Saltburn by Sea
    67
    It certainly doesn't seem to be, I spent an hour in the boot yesterday, I've undone every hex bolt I can see but as you say, the plastic trim panels are still being held in place by things that you can't see until the boot it open. I'm at a loss, it looks like a big garage bill to get it sorted.
    Sep 2009
    Mid Sussex
    162
    You might be able to get a terminal screw driver (from the inside the boot) to the lock bit it's self and move the slider/claw manually. Makes sure it is in the unlock position first.
    I had similar problem once, I ended up having to destroy the plastic trim inside the boot to gain access. Holes saws and hack saw blades.... wasn't nice but it works. Then popped up scappy to find a new lock mech and new plastic trim.
    I'm not saying do that, but unfortunately that is the last resort.
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
    May 2010
    71
    Quote Originally Posted by Zonda_ View Post
    There are just two philips head screws that im pretty sure you can still get at from inside the car with the boot shut. (they are at the bottom left as you look inside the car) After you've undone those, the trim is just held on by plugs (in a 4 x 2 grid form the lower and around the outside on the upper trim) which just require force to pull off.
    Jul 2009
    Saltburn by Sea
    67
    Got it open but now it wont latch shut!!
    Sep 2009
    Mid Sussex
    162
    Sounds like the latch it self, you should be able to move it by hand. Maybe leave the plastic trim off and re close it from the inside.
    A3 1.8t quattro -
    Jul 2009
    Saltburn by Sea
    67
    It moves easy enough with a screw driver, I can see the linkage moving when I operate the paddles on the outside. No matter how hard I shut the boot it won't latch but moves perfectly freely otherwise.
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Mine wouldn't latch. Look at the two rubber bumpers on the end of the boot. I tightened them in a few turns and it locked fine.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Jul 2009
    Saltburn by Sea
    67
    No rubber bumpers on it!
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    I'm pretty sure there were some on mine. Could be on the car as opposed to the boot. Like here above the light in the left of the picture
    Is the problem now the boot wont stay shut?
    8L IS DE BEST
