EM TuningAWEsome GTI
Results 1 to 34 of 34
    colicabcadam is offline Banned
    Aug 2010
    823
    Post Thanks / Like
    S3 engine oil, transmission oil, haldex oil, rear dif oil and front dif oil?
    hi guys, i've had a look across the internet but there seems to many different opinions and statements that i do not trust
    i'm about to do a full service on my s3, so can you please advise on the following oils?
    engine oil - Castrol Edge Fully Synthetic 5W30 Engine Oil? is this ok?
    transmission oil - i'm a little confused here, i understand it's 75w90 but some people are saying not to use g5 and to use g4, what do you use, any good brands??
    haldex oil - easy, buy direct from audi
    rear diff - same as transmission oil?
    front dif (if there is one?) - same as transmission oil?
    many thanks
    Google Adsense Circuit advertisement
    Aug 2010
    823
    Post Thanks / Like
    based on the lack of responses, no ones ever had their oils changed on their s3?
    MrCSW's Avatar
    MrCSW is offline Same colour as The Hulk?
    Sep 2009
    719
    Post Thanks / Like
    I use:
    Q8 5/40 synthetic 909.1 for the engine.
    Transmission oil/ rear diff 75/90 synthetic gl5 (from audi)
    Haldex oil + Filter from GSF (slightly cheaper than audi)
    Front diff is part of the gearbox, transfer box is also filled from the gearbox.
    Coolant - G12 (anything which complies to g12 spec)
    Brake fluid - Motul Rbf 600
    Aug 2010
    823
    Post Thanks / Like
    Quote Originally Posted by csweatherston View Post
    I use:
    many thanks for the speedy reply, all makes sense.
    do you know what the capacity of each part is from empty? I don't want to waste money on fluids i wont use..... i cant find any informartion on the transmission and rear diff capacity, engine oil is around 5 litres? coolant around 5 litres? brake fluid around 1.5 litres? and the haldex oil comes in a container that will fil lit from empty?
    thanks in advance
    many thanks
    1animal1's Avatar
    1animal1 is offline The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,817
    Post Thanks / Like
    is there much point in changing the rear diff fluids chaps? its the only part i havent changed as thought it was lifetime sealed?
    Xbox 360 gamer ID : Timffy
    8P3 S3 Brilliant Red - 2010 RNS-E, Bose, Auto Lights/Wipers, Auto Dim rear view, Heated seats, Flat bottomed multifunction wheel, Ipod dock, Aux in, Full phone/BT prep, Interior light pack, Tyre deflation monitor, Rear parking sensors, Fan washer jets/ambient lighting/LED boot lights.
    S3Steve's Avatar
    S3Steve is offline 6th Gear
    Sep 2005
    Peterborough
    1,535
    Post Thanks / Like
    I use Castrol Edge 5W30 engine oil. Motul Gear 300 75w90 for the transmission, which i found was a good improvement and has stopped the common issue of crunching gears when changing between 2nd and 3rd. As said above the transfer box is filled from the gearbox. Havent changed the rear diff oil so cant comment on that although i thought it was 75w85 not 75w90 like the gearbox. Might be worth having a look on opie oils website mate as they always have good info and offer good prices especially with the forum members discount we get.
    2002 S3 | Jabba Remap | Bailey Dv | Bilstein B8's | H&R Springs | 8.5x18" BBS CH's | Supersprint Exhaust | Samco's | Brembo's
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,535
    Post Thanks / Like
    Quote Originally Posted by 1animal1 View Post
    If you listen to audi the transmission oil is sealed for life too but it made quite a difference when i changed mine, so im thinking it might be worth changing the rear diff oil too.
    MrCSW's Avatar
    Sep 2009
    719
    Post Thanks / Like
    All my sources tell me the rear diff is the same oil as the g/box (audi/tps/gsf/caldo oils)
    Rear diff takes just over 1ltr, and when i drained mine it was as black as the ace of spades... certainly wont hurt to change it (only take 5 minutes too)
    Aug 2010
    823
    Post Thanks / Like
    thanks guys, no matter what audi or any other manufacturer says, no oil is life long, all oils degrade over time, just some faster than others.
    any news on the transmission oil capacity?
    MrCSW's Avatar
    Sep 2009
    719
    Post Thanks / Like
    sorry, i thought i put it in the above post. oops.
    Gearbox is just over 3 ltr, Rear diff is just over 1ltr ( I did mine last week so its still fresh in my mind)
    Gearbox you'll need to fill once, then run it up to circulate into the tranny box then top it up again (first fill took 2.5ish, second too just over 1/2 ltr)
    Aug 2010
    823
    Post Thanks / Like
    nice one, thanks, i'm sure others will use this thread, good input!
    Andy´ is offline Neutral
    Stockholm / Sweden
    52
    Post Thanks / Like
    Quote Originally Posted by colicabcadam View Post
    Yepp right on time. Was about to do all the oils too. Thanks guys for the info.
    S3 225 BAM
    Stage 1 TuningChip, AEM Dryflow cone filter, 19" OZ Superturismos
    The Doctor's Avatar
    The Doctor is offline 4th Gear
    Jul 2009
    Nottingham
    729
    Post Thanks / Like
    I've done the Haldex oil & filter, but I keep meaning to do the rear diff on mine. Where's the drain screw and how do you re-fill it?
    S3 Nattie's Avatar
    S3 Nattie is offline Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Post Thanks / Like
    Very good info. I was going to do my gearbox fluid soon and though it took 2.6 ltrs from full to empty, didnt know the tranny box uses the same fluid.
    When you say run it up to circulate the fluid into the tranny, what should you do exactly. Drive the car up the road or start the engine and go through the box a couple of times.
    Nathan
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    MrCSW's Avatar
    Sep 2009
    719
    Post Thanks / Like
    Nattie - I ran mine up the road and back... Not sure if cycling through the gears stationary would work the same as effectively nothing is spinning. (unless you have the wheels off the floor (wheelfree ramp etc))
    Doctor - The drains a 17mm allen plug on the bottom of the diff casing, The fill/ level hole is also a 17mm allen plug but on the front of the casing (approx halfway up)
    The easiest way to get to the fill plug is with a plug tool like: http://www.toolbuddy.co.uk/ekmps/sho...ford-815-p.jpg
    and a spanner as space is pretty restricted.
    For anyone intrested the gearbox drain is a 14mm allen, as is the level/fill plug. The tranny box drain is a 12mm allen.
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Post Thanks / Like
    Thanks for the info. So just unplug the transfer box drain plug and gearbox drain plug then refit and refill through the gearbox filler plug till the fluid comes out of the filler. Go for a drive then refill again till fluid comes out of the filler plug, I should be able to do that if thats the right procedure lol.
    Does anyone know where is the cheapest place to get Motul Gear 300 75w90 from, not the net though. Will need 4 litres for transfer and gearbox ye, 3 litres wouldnt be enough.
    Nathan
    For sale
    PM for info.
    barters3's Avatar
    barters3 is offline 2nd Gear
    May 2008
    440
    Post Thanks / Like
    Quote Originally Posted by S3 Nattie View Post
    Nathan
    When i ordered my gear 300, camskill was the cheapest. I think opie oils have got a sale on motul oils at the moment.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,817
    Post Thanks / Like
    Spoke to my Audi tech today who says theres no diff on the back, just the haldex...... im sure you guys havent dreamt it :/
    barters3's Avatar
    May 2008
    440
    Post Thanks / Like
    There's defiantly a diff...... its the first thing people warn about when changing the haldex oil. ie, not to remove the drain plug on the rear diff instead of the haldex drain plug.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,817
    Post Thanks / Like
    in that case i shall challenge him
    S3 TAM's Avatar
    S3 TAM is offline Hole in pocket getting bigger!
    Oct 2009
    London & Hertfordshire
    474
    Post Thanks / Like
    Sorry to repeat but just need to make sure I understand it before doing this.
    Right so i need to undo the gearbox and tranny plug's "do i need to warm the oil up a tad before doing this?" drain oil out then fill up with oil till it comes out the filler, then drive it round the block. then refill till it comes out the filler again job done.
    Can i use the same gearbox oil for the rear diff?
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    FOR SALE
    STANDARD DOWNPIPE & CAT'S
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    Welly's Avatar
    Welly is offline 8L S3 - Badger 5 Edition
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    What was the outcome Tim?
    "All right, let's not panic. I'll make the money by selling one of my livers. I can get by with one." Homer Simpson
    Welly & Bumble
    FP Green - 411 BHP/330 LBFT
    Badger 5 Edition....
    rossbrownlee is offline Ross_S4
    Aug 2009
    Dundee
    716
    Post Thanks / Like
    Quote Originally Posted by S3 Baby View Post
    Alright mate, don;t want to teach a granny to suck eggs but...
    Would advise you to take out the filler plug first BEFORE taking out the drain plug. would be terribly embarrassing to drain the oil and not be able to top it up again...
    Westy's Avatar
    Westy is offline K04 Murderer!
    Dec 2008
    Hertfordshire, sometimes Cambridgeshire
    11,365
    Post Thanks / Like
    There is definitely a rear diff. I had my oil replaced and watched my Audi specialist do it.
    Tims Audi mech must be pants
    WANTED - Rocker Cover (push down coil pack type)
    PM me
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    I had a chat with my Audi Tech yesterday he said you need to put "final drive oil" in the rear diff not gearbox oil.
    Am I right in saying Final Drive oil is thicker than gearbox oil?
    What spec is final drive oil. 75W90 or 75W85?
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    Will this stuff do both gearbox and rear diff??????????????????????????????????
    Motul MOTYLGEAR 75W-90 Gearbox and differential lubricant Technosynthese
    Motylgear 75W-90
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
  28. #27
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    Sorry to revive a thread but, I've just finished changing my rear diff oil and i noticed the bottom plug had bits of metal on it is this normal?
    Edit: mine only took about 800ml of oil aswell.
    here is a pic of the oil BLACK.
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
  29. #28
    Mr.G's Avatar
    Mr.G is offline 5th Gear
    Nov 2008
    In a Tardis!!
    1,303
    Post Thanks / Like
    Recently had a full overhaul on transmission with Awesome GTI. Diff oil, Service and haldex replacement unit along with haldex oil/filter. Engine service carried out too. Big difference if the oils are changed in the diff.
    G
  30. #29
    Dazboss's Avatar
    Dazboss is offline Like A Thristy Dingo ;)
    Jul 2010
    West Midlands
    366
    Post Thanks / Like
    I need this job doing very soon, along with gearbox (h)oil.
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
  31. #30
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    Next on the list is gearbox oil, then all the fluids will be fresh.
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
  32. #31
    b1gdave83 is offline 1st Gear
    Sep 2009
    Mid Sussex
    162
    Post Thanks / Like
    Rear diff oil defiantly different from the gearbox, it's thicker. I just went to TPS for correct oil's.
    Rear diff - 1 litre
    I was told gearbox was 2.1litres (6 speed quattro) (I measured what came out 2.1 litres)
    3 litres!! Now I'm confused
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
  33. #32
    Sep 2009
    Mid Sussex
    162
    Post Thanks / Like
    I found this
    VWVortex.com - DIY: Transmission Fluid Change for 6 Speed O2M
    Hope it helps
    Looks like qty is any were between 2-3 litres.
    A3 1.8t quattro -
  34. #33
    Sep 2009
    Mid Sussex
    162
    Post Thanks / Like
    I'd say yes that's wear, I didn't have as much as you but mine had 65K when I changed it. I presume you have higher mileage.
    Thats the reason why I don't think it is sealed for life I don't care what Audi say. It's good that they have made the plug magnetic stops those little metals shavings causing any damage, but still I wouldn't want them in there.
    A3 1.8t quattro -
  35. #34
    elvo's Avatar
    elvo is offline Reverse Gear
    Aug 2010
    26
    Post Thanks / Like
    iv recently had my rear diff oil, haldex and gearbox oil done and it made such a big difference. Iv sill to do the engine oil however im still unsure of what oil to use. Would this oil be ok Castrol Edge 5W30?? thanks
