EM TuningJMB Retrofits
Page 1 of 2 12 LastLast
Results 1 to 40 of 47
    Jun 2007
    624
    Erratic Revs on Start Up
    Hi, I've an S3 8L and I'm seeing something strange - has anyone seen this before when starting up http://www.youtube.com/watch?v=5H1axtcj5MM ?
    When I start the engine from cold it jumps up to 1300 revs...then slowly works it's way up and down until it gets to about 900 revs. Almost as if it is doing a throttle body realignment.
    rlc1985's Avatar
    top gear
    Aug 2010
    Coventry, United Kingdom, United Kingdom
    124
    choke?
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    S3 8L - your rev counter has an analoge clock - mine don't have that ? it's an led one.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    Aug 2010
    1,540
    does it take slightly longer to start and seems very slightly down on power too?
    had one in at work few months ago and the crank sensor had gone down? was a similar complaint by the customer as what you describe. and weirdly enough, it didnt put the management light on despite the cranksensor fault being in the memory
    does it cut out if you unplug the cam sensor? it should make no difference plugged in or not on idle.
    when the cranksensor goes down, the engine management uses the cam signal to run the engine in a limp mode.
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Pretty sure mine jumps up to a similar level when cold but drops down to 720/760rpm according to vagcom and the dial when warm. I understand it to be the automatic choke, but if it stays at 900rpm that's a bit higher than mine. At a guess would say maf, coolant sensor, crank sensor anything to do with engine speed, air flow and temp that's off fooling the ecu into giving it more revs.
    I'm sure one of the more knowledgeable guys will be along shortly to correct me or give you the right answer.
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
    paneristi232's Avatar
    79
    Quote Originally Posted by thegoal007 View Post
    Its a non facelift S3 8L.
    J
    AUDI S3 2002 225 BAM ABSOLUTE RED, SUPERSPRINT MAGNUM, 18" RSTT WHEELS
    Madeley's Avatar
    Jun 2010
    Telford
    125
    l have the same problem and my temp gauge takes along time to kick in, l put a new temp sensor in yesterday and l still l have the problem. This is odd.
    S3 2000 AMK car with a APY engine, minge blue, rs6 alloys and Revo'd by Badger5
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Also check for vac leaks under the inlet manifold.
    May 2010
    224
    Thats exactly what mine does! I have changed the maf and coolant temp sensor, still there. I dont have any tempreture issues though, mine reads ok. must be the crank sensor?
    Jun 2007
    624
    Quote Originally Posted by murran View Post
    By the "fault being in the memory", do you mean it showed up when you did a diagnostic scan?
    I don't have anything shown up when I scan the engine module.
    Ive never tried unplugging the cam sensor...is there any online pictures or diagrams that might show me where it is, I could try it
    colicabcadam
    mine does it, but it dies down pretty quickly, i thought i was simply a fast idle to help the car warm up / start up.
    May 2010
    224
    Yer i thought it was just something the car did when cold.
    Jun 2007
    624
    Quote Originally Posted by drfeelgood View Post
    I don't think so. My car never used to do this. Plus it doesn't happen consistently.
    If it was something "normal", then it would happen consistently on a cold start.
    For example, I've seen this on a cold start on days when it's 20+ degrees outside, and I haven't seen it on other days when it's a lot colder outside.
    May 2010
    224
    happens to mine consistently on a cold start, or any time over 7hrs, can anyone point to what the possible cause of this is?
    XFi
    Jun 2010
    344
    Quote Originally Posted by metricspaces View Post
    Outside air temp does have an affect on this. But if the engine is cold it is cold regardless of the air temp. If the coolant was warm then this wouldn't really happen. Happens on my car every time I start it regardless of temperature.
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    Same problem here, i presumed it was the maf... I am ordering a new one but sounds like it hasn't fixed your issues!
    Mine when cold turns over for ages and sort of chokes into life with revs around 1300 too after a minute or so dropping back to around 800! Seems quite common!
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Mines recently started doing this, although i've seen no other side effects. Would be interested to know the reason.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Well mine does suffer from some of these issues, i know for a fact i have 3 vac leaks (2 are due to split rubber hoses in the pcv system and the other is my rocker cover gasket that is leaking) and i need a new maf, will be interesting to see if these 4 things when fixed will cure my problem.
    May 2010
    224
    I will take it into Audi and see what they say, However wont be for a while
    May 2010
    224
    You know i have a feeling a pipe is slightly spilt and causeing it to over rev untill it heats up and closes the slight spilt
    barters3's Avatar
    May 2008
    440
    i have noticed mine has been doing this recently from cold. I have replaced the coolant temp sensor and the vac pipe arrangement under the inlet mani. I did not replace them to cure this particular fault though, i thought it was reasonable for the revs to do this from a cold start. I havent got vagcom so i think il keep an eye on it. Interesting to know the outcome of this thread tho....
    May 2010
    224
    I'am asking mechanics on that "just answer" , at 22 quid i better get a good answer lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    oh dear.....
    Jun 2007
    624
    Yeah, think I will be looking at all the areas mentioned
    1) VAC leak - visual inspection & get it pressure tested
    2) Replace temp sensor- only a few pound, might as well
    3) Replace thermostat - only a few pound, might as well
    4) Replace crank sensor
    As for the MAF, I only replaced my MAF a year ago, doubt it's gone again, but might check that too. Anyone know how you'd check whether the MAF is causing this issue? The normal test for the MAF is running up to the redline and recording the airflow with VAGCOM...if this shows correct g/s figures, then you know the MAF isn't causing any performance issues, but could it still be causing this problem at low revs\start up?
    It would seem strange if it was the MAF. If you've a dodgy MAF, then you will always have performance problems. Whereas this startup issue is sporadic.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Issues such as this are 99% down to vac leaks. Hunting at idle, erratic idle on cold start, they are all typical symptoms of vac leaks. So many have had them on here now...
    Homer Simpson
    Jun 2007
    624
    Thanks. What's the best way to pin down where the leak is?
  28. #27
    Loupigs's Avatar
    69
    My 2002 A3 sort of did thism, fixed when the throttle body was cleaned out of all it's gunk.
    You aren't stuck in traffic.... You are traffic
  29. #28
    talentwalsh's Avatar
    May 2010
    Galway
    139
    I have the same issue, it gets worse when the engine is 30 deg +. Checked for leaks, cleaned the TB and no difference. Pretty sure its the crank sensor but at €110 im reluctant to change it. Does it take longer to fire than normal especially when warm? If so prob the crank sensor.
  30. #29
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Can't you get one from a scrapper to test before buying? That's what I'd be doing.....
    At least that way you can tell if your sensor is shot.
    Homer Simpson
  31. #30
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Mine does this too and since changing the clutch switch did not solve my over revving problem when changing gear on boost, I reckon ive got some spilt pipes some where
  32. #31
    May 2010
    Galway
    139
    Id love to check it Welly but S3's are as rare as three balled pitbulls in Ireland so no chance getting one from a scrapper. Im STILL waiting for my VCDS to arrive to see if it throws up a fault for it. Until then its crank and pray!!
  33. #32
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by talentwalsh View Post
    Bugger.....
    Homer Simpson
  34. #33
    239
    Could this have anything to do with the PCV valve and the pipe which returns to the intake pipe?
    mine does something similar, hav just seen the the return pipe is degraded badly
  35. #34
    Aug 2010
    1,540
    the cam sensor is in a metal cap on the end of the inlet cam on the cambelt end of the engine. theres a 3 wire plug directly on to it.
  36. #35
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Did anyone solve this? Have people with these symptoms recently changed any coilpacks?
    > S3 225 (03) - OEM+
    View: My S3 diary
  37. #36
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    did he clean his throttle body?
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
  38. #37
    Apr 2010
    6
    tick over
    hi mine used to do that so i got fed up with it and tuck it to a higly recomended bosch master tech and it was just the coolant temp sender or loom to it he changed both as they were cheap, my car also turned over for abit before starting and cracked wen warm as if the timing was out but the sender and loom did cure this,
    however whilst on his computer he noticed it was running 15% lean but i didnt have the time or money to let him find out why any suggestions?
    thanks
  39. #38
    May 2010
    71
    For the car to rev higher when cold is totally normal.
    I had a look at mine on the drive home and it sat at about 1100 as i started it (so about 50rpm lower than yours), although I didnt hang about to see what happened after that.
  40. #39
    May 2010
    224
    I cleaned the throttle body, was a bit grubby, however problem is still there. its annoying as when cold, the increased revs give the car a slight jerky sensation when driving, also if going up a slight hill, the car continues to accerate even with the foot off the pedal. right werid it is. Its going to audi on wednesday, and im not takeing it back till its sorted! lol
  41. #40
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    This isn't totally normal, as mine didn't do it until the last few weeks (i've had it for 4 years). I've done a vagcom scan and it's coming up as running rich on bank 1, which just happens to be the same bank as the coilpack I replcaed recently. I'm going to replace the coilpack for a newer version (its currently an old one I had lying around) and see if that influences the idling issue (as the idle issue started around the same time as replacing the coil pack).
    > S3 225 (03) - OEM+
    View: My S3 diary
