Monster MotorsportEM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
  1. #41
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I thought the revs were supposed to rise when the SAI is on to aid heating the CAT.
    I look forward to the outcome from Audi
  3. #42
    Jun 2007
    624
    This isn't normal. Otherwise my car would always have been doing it - it only started doing it recently, it doesn't always do it on a cold start either (regardless of how hot\cold it is outside).
  4. #43
    May 2010
    224
    Well i took it to audi, and they couldent find anything, in typical fashion "oh the computer is not showing any issues" ****ing computer, christ do all these guys do is plug a computer in and itch there arse for an hour looking at graphs? They got a bit surprised when i told them it could be a vac leak past the maf, so the computer might not register there being a problem,
    at least they re-alligned my drivers door so it dosent keep catching the lock, free of charge, but yep typical useless audi, will take it to a specialist when i can be bothered.
  5. #44
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Issues such as this are 99% down to vac leaks. Hunting at idle, erratic idle on cold start, they are all typical symptoms of vac leaks. So many have had them on here now...
    You mentioned this to me a while ago buddy, when I mentioned my idle when warm and cold is a little uneven. Think you said it was a specific system, like the n247 or something, that regulates cold air on start up?
  6. #45
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    That was the SAI system - the secondary air injection system but only the APY has it. Also, the N112 valve regulates that on the APY engines.
    All the S3 variants have the N249 valve assembly, which is that mess on top of the rocker cover. Notorious for leaking as there are so many joins.
    It's normally an inlet manifold vac hose.
    Easiest way to find out is to reset fuel trims by clearing fault codes, and then monitor short term fuel trims in block 032 in VAG COM. If the number clicks up - hello vac leak.
    Homer Simpson
  7. #46
    JD09's Avatar
    Dec 2009
    3,080
    Lol.
    That's like me talking to you about CTRs, ORs and the percentages to go with them, i.e. means **** all to me lad
    Might have to bob down your way when I get bored over a weekend. Get you to show me the yellow bus and the wonders of using this software and lead I have sat here!!
  8. #47
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Always welcome dude!
    Homer Simpson
