Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Nov 2004
    21
    17 psi with s3, is it too much?
    Some said that over 15 psi is dangerous for an s3, that much pressure breaks the pistons. After chipping mine boosts 17 psi, Am I in danger ? (it doesnt go to limp mode)
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: 17 psi with s3, is it too much?
    [ QUOTE ]
    [/ QUOTE ]
    17psi is about 1.2 bar... THis aint going to break anything! S3 can handle about 1.7/1.8 reasonably safely althogh i wouldnt want to for any period of time
    Rich
    Nov 2004
    21
    Why wouldnt you want to , isnt more boost more hp ?
    Also the same one said that even subaru breaks pistons over 15 psi , more comments ?
    Oct 2003
    South Wales
    2,942
    [ QUOTE ]
    [/ QUOTE ]
    you may get more power but the turbo will be stressed and it will only be a matter of time before it goes.
    Oct 2004
    22
    the standard revo map runs 17psi which is (low boost 9)
    i have this setting on mine and does not seem to be stressing too much.
    May 2003
    North West
    202
    my revo map (98 ron using sps2) boosts to 1.45 bar then slowly drops to around 1.05 bar at 6400rpm
    i believe 1.45 bar is about 19psi.
    Mark
    Sep 2004
    Central Scotland (where it rains alot)
    144
    Up, this is the same as mine Mark.
    Can, the Jap stuff does tend to run less boost the the VAG engined cars for some reason.
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    No... More boost is more torque, not HP. You can increase the boost and make a big difference in torque while barely changing the HP figure.
    Rich
