Sky InsuranceVolks Autos
Results 1 to 39 of 39
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Water methanol injection
    Anyone running water meth??? im really thinking of doing it want as much from the std turbo as i can and also want to keep things cool.
    can you run it off the washer bottle i have read about washer fluid which has meth in it? if so that will work? if not can you use water and mix it with meth and still use it as washer fluid?? as there is'nt really anywhere to put the bottle otherwise..
    thinking of the devils own kit which is tailored for the vag range. any good?
    basically any info please!! cheers
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    Washer fluid is easy to get hold of, most of the time it doesn't contain methanol but something else instead.
    Its find to use in water injection taken from the washer bottle
    I was looking at AEM kit
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    was just thinking about the same thing. also quite interested in this.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    washer fluid is often as not ethanol not methanol so you should look for those using methanol only..
    ideally a seperate bottle is better as you have more latitude on % mis then without worry about rubbers or paintwork from screenwash with too much meth in it. the appeal of low level warning however on the oe bottle makes it a neat easier install.
    stage 2 kits with progressive controllers work best,
    you can choose your % mix to run if you want it for cooling only, or to tune for it..
    kits i have used so far include aquamist, snow performance and devils own.. labonte is the current kit i am looking to use here on customer cars..
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Interesting, so would it be ok to substitute a fmic for meth injection to lower intake temps on a hybrid k04?
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Most of the cheaper kits make you use your washer bottle n may supply a smaller one for the washer fluid. You can get methanol pretty cheap n IIRC it takes about 2-3 tanks of fuel to get through a gallon of meth (depending on how hard you drive obviously). You can use just water to achieve the cooling side of things (make sure its distilled though) or mix half meth n half water to obtain both power n cooling. If you want to go mad theres a 1000 litre bottle of meth on the bay for 350 lol, should last you a while.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by sandip View Post
    Id get the fmic as well for added cooling.
    PS3: Broady_11
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    have you got a 'kit' that would work on an s3?? also how about mounting the bottle somewhere? ideally i think id rather use a seperate bottle but its just space. devils own do bottles which you can fit a level sensor into which is good
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    not substitute no, supplement
    bill@badger5.co.uk
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    Quote Originally Posted by s3_kev View Post
    Devils Own or labonte do stage 2 kits with bottles, level sensors as accessories etc.. For VAG 1.8t's I have supplied and fitted these to, pump and bottles have varied from OE washer bottle with pump in inner wheel arch or boot mounted, and some meth bottle in boot with pump.. Kits are from 360 as a guide price.
    bill@badger5.co.uk
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    not really wanting to go as far as to mount bottle in the boot tbh, what sizes are the bottles that would come in the kit?? would like to mount it engine bay area ideally.. if i was to use oe washer bottle how would i go about using the washers as normal use??
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    "kit" is whatever size bottle you want.
    http://www.methanol-injection.co.uk/...630fd58b26d240
    If using washer bottle, you use it like normal.. subject to what I have already said re % mix methanol
    S3 engine bay is not blessed with space for a decent sized bottle in my experience.
    bill@badger5.co.uk
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    ideally a seperate bottle is better as you have more latitude on % mis then without worry about rubbers or paintwork from screenwash with too much meth in it. .
    this is the part that worried me abit? if i were to use a methanol only washer fluid would you use a low concentrate mix without the worry of damaging paint or rubbers? i guess methanol dosent damage if low concentrate as its used in washer fluid already.. just want to know the score before parting with my cash and being left with knackered paint work etc..
    cheers
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    cheers
    if you use methanol type screenwash that should'nt effect anything... remembering most are ethanol based tho
    bill@badger5.co.uk
    S3 Paul's Avatar
    Oct 2006
    2,759
    In real terms bill...
    On a car like mine...
    Say a hybrid, fmic 3inch downpipe and decat... and prety much as far as i can go with things, What benefits and increases can be seen?
    Could a bottel go in the spare wheel well? How big a tank would be needed to last say 300 miles of fun driving??
    Noggy Blue 2001 S3
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    ok well im really considering this as an option so come payday you might well be getting a phone call,
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by S3 Paul View Post
    I think you can achieve another 20-30bhp? Normally 1 gallon of meth lasts 2-3 tanks under normal driving, so driving "fun" maybe 1 gallon will last you 1 tank? Im sure Bill will correct me...
    PS3: Broady_11
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    20-30bhp??
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Quote Originally Posted by 1animal1 View Post
    20-30bhp??
    ..only through timing advance mate... you 'can' dial in more timing advance running WMI as its an octane booster and keeps EGT's/AIT's lower.... I am planning to run WMI but only for added AIT cooling on hotter days... ideal for GTI Inters for example... will make it switch-able so I can choose when to run the stuff... don't really need it for the daily runs or winter days etc...
    Problem with using it for power is if you run out then you get horrendous timing pull which 'could' be a potential engine breaker depending how aggressive you have been....
    Guessing there may be some takers for a group buy on a WMI kit then? ;P
    <tuffty/>
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    sod that...far too complicated...stage 1 rules!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    big girls blouse lol.....
    <tuffty/>
    Morgan-VAGCHECK's Avatar
    Foot to the floor
    Jan 2007
    103
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Hi,
    Best way is to use something like Snows Safe inject which monitors flow. This way blocked nozzle, pump fail, tank empty etc will all be picked up.
    Then get yourself a Grautec module for your ME7.x that will allow for two maps with on the fly switching, then use the safe inject to trigger the map switching via a relay.
    A near perfect solution in my eyes
    Regards
    Morgan
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    im more interested in keeping things cool then to gain performance. im unable to check egt's as apy dont have the sensor but i know it gets hot as when boosting the whole way down a dual carriage way holding 20psi the oil pressure drops loads more then on normal driving/sprints only one reason for that!!
    im still very weary of using my washer bottle incase i use the wroung washer fluid. could i use distiled water and like 5-10% meth and the washers still be ok?? or what would happen if i use any type of washer fluid and water as im aiming for cooling overall??
    id use a little more timming but nothing that would risk damage to the engine in the worst case.
    bill if i were to buy the kit from you and fit my self would you be able to tweek my mapp etc if i was to come to you after instalation? i have AMD mapp would that cause any trouble?
    cheers
    Oct 2008
    188
    id be up for a group buy on wmi set it up boys and witch kit would be best
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    im all up for it too, set up the group buy
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    consumption is all down to how you drive those 300 miles.
    its a progressive kit, which has a start psi for spraying, and full on psi for spraying flat out.
    the middle size DO bottle seems to match a tanks worth of fuel
    benefits of rediced aits, egt's and if you decide to use a higher % meth, some more timing can be added which is more power.
    wmi keeps the car very consistent, not heatsoaking like they do otherwise
    bill@badger5.co.uk
  28. #27
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    cheers
    no problems with that
    bill@badger5.co.uk
  29. #28
    S3 Paul's Avatar
    Oct 2006
    2,759
    Its the using it to gain more power part that slightly worrys me... As if the car runs out of the meth mix. Will the car damage itself?
    Can the ecu pull enough of the added timing out for things to run normal? As when out and about i would expect meth isnt that easy to find?
    Can just water help ? or is the use of water just to keep things healthy rather than aid power?
    As for how the 300 miles or so would be driven ... maybe only half of them would ever be driven hard
    Noggy Blue 2001 S3
  30. #29
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    meth is easy to find round here... bio-fuel peeps use it..
    model shops also sell it
    if you run out and have maxed out the timing to make use of it, then yea, you will be on the edge of what the ecu can pull back.. flow devices to say when its not working are available to warn of this.., and in some respects connect to the n75 also to limit the boost to actuator pressure..
    typical adjustments i have seen and done myself, when running 50-50 mix have been able to take 8.25 degrees advance extra..
    loose wmi with this much advance then the ecu cannot pull out enough timing.. so in this respect, running out is bad.
    bill@badger5.co.uk
  31. #30
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Surely having 2 maps would solve this. Runs out of wmi then it switches to the map that is programmed without wmi?
    PS3: Broady_11
  32. #31
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    cant you only get one map on the S3 standard ECU?
  33. #32
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Yeh but cant you get a seperate module with the other map on it??
    PS3: Broady_11
  34. #33
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    dunno fella....just thought i rem someone once saying
    but then saying that, APR used to be able to do a switchable map via the cruise button (modified to standard) so it must be possible in one way shape or form
  35. #34
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    u can different switchable maps.
    u cant use wmi just for cooling.
    it is really not advised to use the same tank for the washer flui and wmi. (as bill said, for paint and rubber issues, for % of methanol and water u got, for the heat that might cause the methanol to make the plastik container of washer fluid shrink)
    most of the performance is due to the fact that you can pull more timing advance,(con rods and uprated internals are recommanded...again)
    and the other thing is that it adds octane to your fuel so you basicly get better ignition.
    the kit i used on my previous turboed car projects, mainly my W124 300E benz, is made by coolingmist. it is a progressive kit and it works like magic. it have a flow sensor so it is more secure than most of the kits available. have a look
    http://www.coolingmist.com/detailmain.aspx?pid=VC2FS
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
  36. #35
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by Chlippo View Post
    cheers for some good input... now i gota make my decision.....
  37. #36
    Jul 2010
    10
    as a professional chemist im drawing your attention to this
    'POISON! DANGER! VAPOR HARMFUL. MAY BE FATAL OR CAUSE BLINDNESS IF SWALLOWED. HARMFUL IF INHALED OR ABSORBED THROUGH SKIN. CANNOT BE MADE NONPOISONOUS. FLAMMABLE LIQUID AND VAPOR. CAUSES IRRITATION TO SKIN, EYES AND RESPIRATORY TRACT. AFFECTS CENTRAL NERVOUS SYSTEM AND LIVER. '
    'Inhalation:
    A slight irritant to the mucous membranes. Toxic effects exerted upon nervous system, particularly the optic nerve. Once absorbed into the body, it is very slowly eliminated. Symptoms of overexposure may include headache, drowsiness, nausea, vomiting, blurred vision, blindness, coma, and death. A person may get better but then worse again up to 30 hours later.
    Ingestion:
    Toxic. Symptoms parallel inhalation. Can intoxicate and cause blindness. Usual fatal dose: 100-125 milliliters.
    Skin Contact:
    Methyl alcohol is a defatting agent and may cause skin to become dry and cracked. Skin absorption can occur; symptoms may parallel inhalation exposure.
    Eye Contact:
    Irritant. Continued exposure may cause eye lesions.
    Chronic Exposure:
    Marked impairment of vision has been reported. Repeated or prolonged exposure may cause skin irritation.
    Aggravation of Pre-existing Conditions:
    Persons with pre-existing skin disorders or eye problems or impaired liver or kidney function may be more susceptible to the effects of the substance. '
    Taken from the MSDS http://www.jtbaker.com/msds/englishhtml/m2015.htm
    If your spraying that onto your window over an extended period of time.... just so you know.
    Now back to the fun...
  38. #37
    www.badger5.co.uk
    May 2004
    nr Glos
    6,940
    and allowing for the fact its not neat meth, its a maximum 50% water meth mix, will reduce those risks massively.
    some screen washes have ethanol, some have methanol in them, but to what concentration i dont know.. no more than 10-20% tho i dont expect
    bill@badger5.co.uk
  39. #38
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    im very weary of using the washer bottle anyway now you have made me even more worried, looks like i will deffinantly need to find a location for a seperate bottle if i still decide to go a head
  40. #39
    Jul 2010
    10
    plastics not my area of expertise but i wouldn't want any plastics/breakdown products going into your engine. so make sure you get an inert plastic bottle suitable for methanol and should be fine. also be aware that the methanol and water will evaporate off at diff rates with the temp in engine bay so the mixture ratio will change over time.
    something like this, dont know what they make washer bottles from.
    http://cgi.ebay.co.uk/500ml-Teflon-P...ab_Supplies_ET
