AH FabricationsEM Tuning
Results 1 to 14 of 14
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    My slightly broken CV joint (with pics :))
    New shafts arrived today - top notch. Well impressed. No splits at all in the boots.
    For anyone interested - the shafts from a TT Quattro will indeed for an S3 with no problems at all.
    So..... The inner CV joint that was knocking? Oooooooohh dear. It was FUBAR in a whole new way.
    For openers, I removed the CV from the box and found the circlip for the joint sat in the back case, in the grease. Not good.
    Anyway, the damage was quite impressive to be fair. The balls were OK-ish - a few dents and grooves aside.
    The bearing race and inner cage however, were impressively broken.
    Even the circlip has signs of wear on it.... Somehow.
    Anyway, I have my suspicions that this may be the cause of the my mysterious 'clunk'.
    The outer boot also had 4 separate tears in it, and was dry as a bone.
    Fingers crossed.
    PAS not fixed yet so couldn't test drive
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    That not too bad Welly, you should see the CV's we have back at work the shattered. Those can be recon'ed
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
    Apr 2010
    61
    That looks good considering it ran dry. Normally the cage is in about 5 bits! On my track car I had the cages shot peaned to remove the stresses and fingers crossed keep them together longer!
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by luckydave View Post
    Thats the worst joint i've ever seen to be fair, but then again, I've never run them dry before.... lol.
    It was making one hell of a din...
    Homer Simpson
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Dazboss View Post
    LOL, na, new shafts FTW!
    Homer Simpson
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,174
    So what was actualy causing your knocking welly? Was it the inner cv boot? Its just i cant find whats knocking on mine at all and while im buying all my suspension parts i want to sort this out too!
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    It was causing some of my knocking, some knocking was the prop shaft, and the third knocking remains at large..... lol.
    Homer Simpson
    Chugger
    North Devon
    2,716
    3rd knocking?! dam, what a shed
    57 A3 2.0 TDI Sportback (140)
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,174
    Cheers alex.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by sportstractor View Post
    Oh yes.... Tell me about it! lol
    Homer Simpson
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,174
    So even after the cv and prop shaft, it's still knocking?
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Yep, less I grant you, but this isn't a knock, more like a clunk. Bearing in mind I've had the underside apart now as well and replaced the prop shaft.
    Track rod ends and shocks/top mounts suspect.
    Homer Simpson
    S3KO4's Avatar
    Aug 2009
    London
    850
    Welly I have the same clunk noise since day 1, and to date I have not been able to find it I think it must be coming from the shocks I did steering rack, cv joint re grees, bushes but no luck as yet
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by S3KO4 View Post
    LOL, does it drive you spastic too? It makes me soooo mad sometimes.
    Homer Simpson
