EM TuningBadger5
Results 1 to 25 of 25
Thread: Shy turbo...?
    Loupigs's Avatar
    69
    Shy turbo...?
    2002 1.8T A3 AUM, sometimes has zero turbo at 3.5k+, then suddenly kicks in from nowhere. Almost like it's hesitating, can't really describe it any other way. Have been told previously that it's my N75, just looking for any other opinions before I go splashing out. Car needs to be tip-top by Sept 24th as she's off to R-Tech for a Stage 1 courtesy of my lovely toyboy. Also, did a quick bit of research and there's a few on good old eBay but apparently there are different editions and I'll need a 'J'...
    I am SUCH a noob.
    Cheers lovelies.x x x
    You aren't stuck in traffic.... You are traffic
    Apr 2010
    Widnes Cheshire
    404
    Hi. You need to vag-com to read the error codes.
    DC
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    smells like maf
    Chugger
    North Devon
    2,716
    lol lou, i take it you mean jardo?! isnt he a generious jew
    probably is n75 or pipes leading too it. Dont bother with a J
    57 A3 2.0 TDI Sportback (140)
    Loupigs's Avatar
    69
    Quote Originally Posted by sportstractor View Post
    After lengthy investigation I realise that Sportstractor is actually... Custard Dave!!!! Hello dear :-) Yes Jardo is a very generous jew - I think he hopes maybe if he works on my Audi he won't have to drive his Corsa 'Sport' too much lol.
    Now I just need someone to offer to vag-com my car so I can warrant spending my hard-earned pennies on an N75... I'M LOOKING AT YOU PRAWN.
    x x x
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,561
    R-Tech will log the car for faults and do a health check before mapping any way..... you wouldn't want to map a car without knowing if its not well.... they will log afterwards too to make sure the map is not causing any probs...
    <tuffty/>
    Loupigs's Avatar
    69
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Yeah that's cool, I just want it running right before I go up there. But I am loathe to spend 50 on a new N75 without knowing that's definitely the problem. Annoyingly it's intermittent so it'll be hard to tell anyway without doing some miles. It seems to be worst when I'm flooring it.
    Apr 2007
    Surrey
    235
    had similar problem with my mapped a4 and turned out to be the maf at fault but hope for your sake its not as they're double the price of the N75
    2003 S4 Moro Blue Saloon
    Chugger
    North Devon
    2,716
    Quote Originally Posted by Loupigs View Post
    x x x
    what a insult, im not that essex goon. What poor investigation skills. I hope you persuasion skills are better to help prawn part with his healthy N75
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    haha, I think you've been dissed there J, I wouldn't let some bird call me Custard and get away with it!
    Pigs: I reckon it's most likely the MAF sensor, sorry I didn't reply to your text, my fingers are too fat to use the iphone keypad
    you DO NOT need a J valve, no matter what jardo tells you, you need a standard N75 for your car, which would be an F on the latest revision i believe.
    More likely to be the MAF though
    Next time it does it, try unplugging the maf and see if the problem goes away.
    Also, just buy a vagom lead too, 12 on ebay for a shareware version that'll read all your fault codes
    Loupigs's Avatar
    69
    My 'careful investigation' was to ring Jardo and ask 'who is Sportstractor' lol so maybe I should have tried harder....
    My new guess is..... James Hayes?
    Prawny I have texted you like 3 times in the last week and you havn't replied, why don't you love me? Twasn't Pigs who said to get a J valve, and I know I don't need one anyways now. I'm currently skinters so won't be buying anything anytime soon so maybe you should be a love and bring your clever computer stuff down with you at the end of the month...hmmmmm? Pretty please? You know you'll love diagnosing faults with my car.
    x x x
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    x x x
    LOL, this is quite an entertaining read....
    As said before, unplug the MAF and see what's what when it does it again, although fault diag is deffo the quickest and best method to go for.
    Bear in mind though that faults such as this don't always rear their heads at that point .
    Stick with the standard N75 as said before.... There is a post up with comparisons between the valves, with dyno prints and the standard valve is deffo better...
    Homer Simpson
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,064
    Visit 16Klappe's Instagram Channel
    The reason why your turbo is shy is because its so freakkkkin small! I'm only spending money on your car so its better for me when I give you a grand for it this time next year...when you're getting an RX8 wether you like it or not!
    Also, don't diss the Corsa Sport (lol)! All of my interior works fine and it hasn't got any boost problems! And its done less miles and is 10 years older!!!!!!!!!!!!!
    I can't wait for my new car, S2, G60 Corrado, VR6 Mk3, R5GTT, another 205 GTI....the list is endless....nomnomnom
    I quite often say I'm going to do things.
    Then never do them.
    Loupigs's Avatar
    69
    It hasn't got boost problems because it has no boost. Goon.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    x x x
    women are such users! at least i think ur a woman.
    seriously a lead is soo cheap. do it urself ull feel good about it
    http://www.dealextreme.com/details.dx/sku.37635 - free delivery 8. (ive used them before theyre very good)
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Loupigs's Avatar
    69
    Quote Originally Posted by DaveA3 View Post
    Rude! I need Prawn's amazing Audi-brain to tell me where I am inevitably going wrong.
    Sep 2009
    Mid Sussex
    162
    Could be N75 not playing ball, turn it round the wrong way. If it massively over boosts then I'd say its a faulty N75.
    Seriously order the cable, plug it in with VAG com and post what it comes up with.
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
    Loupigs's Avatar
    69
    Alright alright I've bought one.... Will post results ASAP
    Loupigs's Avatar
    69
    17705 Fault code found, pressure drop between turbo and throttle valve - check DV.
    So my hesitant car could be because the DV is giving the wrong readings to the MAF, right? So when R-Tech put the Forge 007P on it next month, that'll be fixed?
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,064
    Hope so!
    Flowing 126G/PS at 6120Rpm theres nothing shy about your turbo babe!
    At 2520Rpm it meets the requested boost, then stays bang on the requested boost through to 6380RPM.
    Then never do them.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Sounds fairly good to me! Stock is 120g/s, so you're doing ok there. Dv leak could be causing all sorts of issues, but it's definitely worth cleaning/ replacing the maf, and from my own disappointing experience I'd either replace every single vacuum line, or better still do an n249 delete to avoid it giving you issues
    Loupigs's Avatar
    69
    Quote Originally Posted by 16Klappe View Post
    Hope so!
    The problem is intermittent.... So you wouldnt necessarily have seen it today maybe? Prawn, it won't let me thank you for your post so *THANKS* lol.
    Many loves to you both.x x x
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,064
    Oh Mr Prawn...hurry up and come home?!
    Then never do them.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    10 days boyo........... For two nights only!
Tags for this Thread
