AH FabricationsBadger5
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
  1. #41
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    cheers v12.....good luck with yours fella...only reason i havent gone down the normal route is because the speedo issue appeared almost at the same time making me think theres sumat else amiss.....hopefully it wont do it again
    Tim
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
  3. #42
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    In an effort to not dilute information across different threads, here are my results from my speedo and fuel gauge not working.
    Back ground:
    I had to replace my gearbox as second gear kept popping out after my clutch pedal snapped.
    In an effort to fix the problem quickly I brought a second hand gearbox on 50K.
    After driving for about 25 miles the speedo went dead, the fuel gauge wouldn't sustain and the oil level sensor showed up on the DIS as faulty. The car drove fine and the oil level was well within acceptable limits.
    Action taken:
    The car was returned to the garage where the gear box change was done. The car was scanned and an inplausable signal from the vehicle speed sensor showed up (that cleared) and an unclearable code of short from oil level sensor. The fact that the two problems presented themselves at the same time indicated that there was an underlaying electrical problem.
    The Vehicle speed sensor was swapped out for the one in the old box, this made no difference. Out of interest the Vechicle Speed Sensor (VSS) from the second hand box was taken apart and suprise suprise it had been bodged shut with loads of Silicone. So a new VSS and oil level sensor were ordered and the car was back in the garage in two days time.
    When changing the VSS for the new one the mechanic at the garage noticed that there was a small strip of bare wire from the reverse switch. This switch is the the one that came with the second hand box so it was swapped out for the one in the old box the fuses were then checked (probably should've done this sooner) and the one described in the mkiv's link above had blown. This was replaced and in conjuction with swapping out the reverse switch for the one in the old box all returned to normal. The mechanic noticed the problem after he had replaced the new VSS so whether the old one still worked I don't know. All of the fault codes are now cleared.
    Obviously there are differences in my experience compared to animal's and others that i have read, but the slight portion of wire (2mm) that was exposed from the reverse switch was enough to trip the circuit and knock out some of the dash readings.
  4. #43
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    thanks Dane that is very helpful, after reading loads of threads it appears wiring is the common solution.....im finding/preferring to chase the faults from other people before i start to change hardware...no issues recently though, just the DIS seems a bit out maybe
  5. #44
    Jul 2010
    99
    i believe my fuel guage on the dash is giving an incorrect reading as after filling up half a tank, going home parking up then starting the next morning it only shows quarter tank?
    what do you guys suggest as a first step?
    thanks
    2001 AMK S3, Black, Lowered, 18" RS4 Diamond cut and Black Polished Alloys
  6. #45
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    hmmmm unsure as my S3 seems to have two points, either halfway or quarter, rarely inbetween........
  7. #46
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    ok first how to get the pipes off
    push the clip
    like so
    so then this is the inside of the tank do you have to undo the 4 torx screws to remove the fuel guage sender ??? to clean it ????
    red to red black to black blue to bits
  8. #47
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    awaits Finesse...where is he when you need him!!
    Finger....touch wood ive used her A3 all week without any issues, only thing ive really done is remove the battery and sand the 3 earth points - then rebolt them back down
