Monster MotorsportEM Tuning
Results 1 to 15 of 15
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Turbo - Downpipe gasket
    Got an exhaust blow and it seems (from what I can tell) that its comes from the turbo / downpipe join.
    Any idea how much I should be looking at to get this changed? Looks like a pig of a job
    S3KO4's Avatar
    Aug 2009
    London
    850
    Hi I just bought one of these yesterday, from Audi for 5.50 but trying to fit it is not easy, so I left it and what I did was to check the three bolts are all tight enough, and the top one was very loose, so I tightened it up and the leak was gone, therefore if I was you I would the same, just get some flexi long wrench etc long 17mm to get to them and you would be fine. she runs much smoother and quiter.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Cheers, thanks for the info.
    I take it you accessed it from the top then?
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    I have the same problem, im thinking shall i de-cat
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
    Jul 2010
    bristol
    647
    its not that bad of a job at all, had exactly the same thing on my old a3, bought the gasket from audi (after the parts guy tried to sell me an oil line to fix the problem!?)
    got home jacked the car up and its fairly straight forward really, just dont shear any of the bolts off!! makes a world of difference though!
    Dazboss's Avatar
    Jul 2010
    366
    Im thinking is it the gasket or the cat thats leaking i cant tell, it does sound like a gasket.
    Jul 2010
    bristol
    647
    the cat (or cats if you have quattro) is under the car, the gasket in question is right at the back, underside of the engine pretty much, should be fairly easy to distinguish between the two mate
    Aug 2009
    Hertfordshire/Cambridgeshire
    225
    How do you know if you have a gasket gone? because It sounds like mine is blowing and when I first set out in the morning it makes a weird noise through the revs and then goes shortly after. Dont know what the hell it is!!!
    S3KO4's Avatar
    Aug 2009
    London
    850
    firstly a3 is not comparable with the s3, they have different turbo therefore more restrictions between the two on top of this there is the quattro issue and bigger gearbox, etc a3 quattro engine stays a bit lower and more forward compared to the s3 therefore even that is easier than the s3. with the right tools I would say 2 hours. I had to go under the car and do them up, there is no room from the top at all.
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Think I might have a crack at this tomorrow. Hangover depending lol
    Dazboss's Avatar
    Jul 2010
    366
    So how hard is it for a A3 Quattro ? I will get the gasket tomorrow from work but it does look a pain to change. Yes i thought my cats were under floor cats. So im guessing that there is only 1 lambda sensor on my down pipe ?
    Apr 2010
    168
    How do you know the gasket is gone or the bolts are loose? Do you get some sort of noise that you can describe because i might have the same but im trying to diagnose it but getting nowhere. Is it a "chittering" noise when your either coming on boost or actually on boost? Does it do it all the time or only when warm?
    Aug 2009
    225
    yeah M8arx thats what i get but when it warms up it goes??? trying to figure this out but getting nowhere!
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Hmmm, one bolt was finger tight and hanging out, another appears to be the wrong bolt as it won't go all the way in.
    Tightened one bolt and the car sounds much better, only got a slight leak now.
    Going to buy new bolts on Monday and hopefully that will cure it all together.
    S3KO4's Avatar
    Aug 2009
    London
    850
    Nice one what did I tell you mate, the bolts loosen themselves up every now and then. To answer the rest of you the noise is noticeable from cold start I.e in the morning and if the leak is huge then even under acceleration.
    It's not the hardest job on the a3 Quattro but. Still tight I would just check loose bolts before changing anything.
