EM TuningAH Fabrications
Results 1 to 18 of 18
    Aug 2010
    Cardiff/Hereford
    14
    Exclamation Help With Front fogs
    Hi, i'm wanting to put front fog lights on my 2001 1.9TDI Audi A3.
    I've got the replacement switch that can turn the front fogs on, but i don't have the wiring or the fogs yet.
    I wanted to know if the connector that i have free on the lights wiring loom is the one to connect the fogs to?
    Uploaded with ImageShack.us
    I know i need the fogs + wiring and the plastic holder bit for the bumper, but is there anything else?
    Any help appreciated!
    Oct 2007
    Plymouth
    203
    doesnt look like it mate, iv got a prefacelift and had to make my own loom from scratch... you can get a retro fit kit here which will work a treat : http://www.carmediauk.com/store/132-...g-Harness.html
    FOR SALE:
    A3 Rear Light bulb holders (1 Pair) 10 quid
    A3 front mudflaps £10
    Fallout 3 XBOX360 £5
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    that looks like the connectors for the front fog lights on my 2001 AMK S3, i just replaced one of the connectors recently
    Aug 2010
    Cardiff/Hereford
    14
    Ah thats good then! Think i'll just buy that wiring harness and some cheap fogs from halfrauds. Or source a scraped A3 and get everything from it.
    Thanks!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    Quote Originally Posted by danger S3 View Post
    agreed
    Oct 2007
    Plymouth
    203
    if u look on flebay ul find the real things or rep foglights for about 23ish quid each, im pretty sure the front fogs only has a 2 pin connector???
    FOR SALE:
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    actually i think your right, mine only had 2 pins for the fogs, i never noticed it was 3 pins in the picture. hhhhhhmmmmmmm still looks like the same thing though just with 3 pins, can't think what else it would be
    Aug 2010
    Cardiff/Hereford
    14
    This isn't looking good :/
    Thinking about it, could it be the connector for the electric headlight adjustors? As i don't have them...
    Oct 2007
    Plymouth
    203
    seems like an odd plug as the facelift headlight has a 4 pin plug and the standerd fog into the back of the lamp has a 2 pin... could it be a power plug for a xenon ballast? I have HID's to have no idea, just a shot in the dark
    FOR SALE:
    Oct 2007
    Plymouth
    203
    Quote Originally Posted by fpscod View Post
    tht would be a pretty good guess. the headlight adjuster is an oval plug, cudnt tell you how many pins it has. you could make a loom yourself, dead easy, cosy you about a tenner
    FOR SALE:
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    I think the headlight adjuster is only in the F/N/S wheel arch
    Aug 2010
    Cardiff/Hereford
    14
    Ah okay thanks. The only problem with making my loom is where do i wire it so i can use the original switch? Bit of a newbie with this. Was hoping for a easy way to connect them.
    Oct 2007
    Plymouth
    203
    [IMG]file:///C:/Users/Mike/Desktop/driving_lights.jpg[/IMG]
    This is what i used to fit my fogs :D
    FOR SALE:
    Oct 2007
    Plymouth
    203
    I think tht is the auto adjuster if you have xenons, im thinking it will be for the motor power supply tht you can manually adjust next to the headlight switch
    FOR SALE:
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    ah yeah, sorry i got mixed up
    Aug 2010
    Cardiff/Hereford
    14
    Quote Originally Posted by mike_plymouth View Post
    Ahh thank you!
    The only thing that i can't get my head around is how it's wired to the switch. Probably just because i haven't got it to look at. But will i just be two pins?
    Aug 2010
    Cardiff/Hereford
    14
    Hey, I went and scavenged some of the headlight adjuster motors from a mk1 pre facelift today. The problem is that the connector isn't the same... The motors connector is too small but does have the 3 pins. Does that sound right? As my car is the face lift version. Still haven't got much further with the fogs, tho have fitted the new switch. Need to know which pins to connect the harness I'm to create to... I've got a picture I will upload later of the options.
    Thanks.
    Aug 2010
    Cardiff/Hereford
    14
    Can you tell me which connector number is from the relay in the wiring diagram. And which is two the dipped beam?
    1.9TDI
    Remapped
