Revo TechnikSky Insurance
Page 2 of 2 FirstFirst 12
Results 51 to 94 of 94
  1. #51
    badger5 is offline www.badger5.co.uk
    May 2004
    nr Glos
    3,404
    Post Thanks / Like
    Tuffty's is AMK dude....
    doh!
    Big Brakes, AP Racing, Brembo, Ferodo DS2500/DS3000, Motul RBF660, Remapping, Dyno Tuning & logging, Big Turbo conversions, bespoke fabrication, Race Proven/Winning products and services.
    http://www.badger5.co.uk, Tel:01453822880, Mob:07976 800775
    bill@badger5.co.uk
    Google Adsense Circuit advertisement
    Advertising world
  3. #52
    Welly's Avatar
    Welly is offline 8L S3 - Badger 5 Edition
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    doh!
    "All right, let's not panic. I'll make the money by selling one of my livers. I can get by with one." Homer Simpson
    Welly & Bumble
    FP Green - 411 BHP/330 LBFT
    Badger 5 Edition....
  4. #53
    DJ_Troopa's Avatar
    DJ_Troopa is offline Audi S3 Driver
    Oct 2008
    West London
    1,604
    Post Thanks / Like
    One of my friends on his Mk3 Ibiza Cupra has disconnected his N75 valve also. Hes taken the vacuum pipe off it and kept it electronically connected. He's done this because he says the actuator on his turbo is shagged. He's tried turning the actuator up for more boost but it doesn't do anything! Is it safe to run the N75 like that? He holds boost through the rev range big time, only seems to tail off just before the red line!
  5. #54
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Quote Originally Posted by DJ_Troopa View Post
    As long as the engine is strong enough to take it - and going crazy with it isn't the best idea.
    I've set mine to 22 initially but it kept going into limp mode under very heavy load (in 6th on the motorway for example) so will drop down to 21 psi which is around the requested boost level anyway.
    Safe boost is OK - going mad will cause serious problems.
    Welly & Bumble
  6. #55
    DJ_Troopa's Avatar
    Oct 2008
    West London
    1,604
    Post Thanks / Like
    I hit 22.3 psi peak on my liquid gauge, is that all good? I have a few mods though but i don't know what psi i should be getting? Is there any point of me getting an MBC or should i just keep the N75F i have?
  7. #56
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    I'd stick with what you've got mate, the reason I'm using an MBC is that the turbo wasn't making the requested pressure. It's old and tired... and I think the wastegate is creeping...
    So it needed a little help.
    Welly & Bumble
  8. #57
    Madeley's Avatar
    Madeley is offline 1st Gear
    Jun 2010
    Telford
    125
    Post Thanks / Like
    Ok guys whats egt, these codes are doin my head in.
    S3 2000 AMK car with a APY engine, minge blue, rs6 alloys and Revo'd by Badger5
  9. #58
    May 2004
    nr Glos
    3,404
    Post Thanks / Like
    Exhaust Gas Temperature=EGT
    AFR=Air Fuel Ratio
    AIT=Air Inlet Temp
    MAF=Mass Air Flow meter
    to name but a few abbreviations you see
    bill@badger5.co.uk
  10. #59
    s3_kev's Avatar
    s3_kev is offline Stage2'd!!!!!!
    Feb 2008
    1,917
    Post Thanks / Like
    here are my results from fitting my mbc
    std N75=
    259.02 BHP
    233.58 LB/FT
    MBC + N75=
    261.63 BHP
    250.99 LB/FT
    MBC only=
    262.4 BHP
    260.43 LB/FT
    note all these figures are taken from vagcom the calculated after so gs. was divided by 0.8 and nm was divided by 1.35582
    boost was @ 20psi on std which would drop to 18psi then hold 17psi to red line, n75 and mbc set @22psi peak hold 20psi to redline MBC only set @20-21psi hold 19-20 to redline.
  11. #60
    dannycawsey's Avatar
    dannycawsey is offline cawsey
    Dec 2009
    colchester essex
    320
    Post Thanks / Like
    im running stage 2 map at 267hp but want to try and find a few more horses before going hybrid or bt,
    is it worth me getting an mbc? p.s how comes everybody uses mbcs and not ebcs on here?
  12. #61
    s3_kev's Avatar
    Feb 2008
    1,917
    Post Thanks / Like
    Quote Originally Posted by dannycawsey View Post
    who's stage2 mapp is it?? mine was rr at 269bhp with amd mapp and 312lb/ft so mapping figures should be ignored imo as there not true figures they make them look good!
    no need to waste money on an ebc reallly mbc works and no lights if the n75 is left plugged in
    for the cost of the mbc its not too bad as you do get a slight gain and boost is held higher through out the revs @ the risk of bending rods though..it wont make such a difference that you will decide not to continue wanting a hybrid though if thats what your already wanting
  13. #62
    Dec 2009
    colchester essex
    320
    Post Thanks / Like
    mines got an AMD map also, so i take it there isnt really anything els i can do before turbo except fit my fmic?
    how much psi can u actually run through the ko4 turbo could you reach 280-290 hp with out hybridizing it?
  14. #63
    s3_kev's Avatar
    Feb 2008
    1,917
    Post Thanks / Like
    i think there is a guy on seatcupra.net who runs those sort of figures he's using water methanol so thats whats needed to really help. but really a k04 would be doing well to reach those figures
  15. #64
    Matt82 is offline 6th Gear
    Sep 2009
    Essex
    2,366
    Post Thanks / Like
    so just going on the raw figures (without seeing the plots) it seems the mbc makes it more diesel like with the higher torque spike.
    really tempted to fit one to mine and experiment with moving the boost up and down to see hwo it effects the output. i recon if you brought the boost down it would reduce that spike without killing the top end too much
  16. #65
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Quote Originally Posted by Matt82 View Post
    I'm battling with issue at the moment.
    Full throttle is fine with the MBC as I have set the boost to about 21.5 PSI which is requested boost level of the map.
    The issue is when on part throttle, especially on the motorway for example, the MBC is always trying to achieve 21.5 PSI boost.
    Map at this point is requesting about 3-4 psi and getting WAAAAAAAAAAY more, goes spakko and throws limp mode buy cutting one of the coils.
    A pain. A big big pain.
    Welly & Bumble
  17. #66
    s3_kev's Avatar
    Feb 2008
    1,917
    Post Thanks / Like
    took mine off today, went into limp mode with out even putting my foot down just starts boosting so easy with the MBC its hard to drive but at the same time its very smooth to drive..
    also doing vagcom logs the torque is peaking at very low revs in very quick plots then filters out to quick im scared for my rods so took it off.
  18. #67
    s3_kev's Avatar
    Feb 2008
    1,917
    Post Thanks / Like
    since refitting the std n75 my boost has dropped again to 17 18psi if im really lucky and im proper annoyed as prior to fitting the mbc i had just fixed my long term boost issue and boost was at 20psi easily 21 sometimes.
    can fitting the n75 pipes the wrong way around damage the n75?? as i made a mistake and got them the wrong way for a bit... also i think i may have a slight tear around the n75 where it goes into the TIP im going to silicone that tomoz to eliminate that but could that cause boost loss too???
  19. #68
    harty190486 is offline Reverse Gear
    Oct 2009
    Post Thanks / Like
    i have a Lcr with cc stage 1 remap, fmic, decat, filter, descreened maff and have been playing with my unos and found i had the same problem on part throttle also getting maff signal to high due to part throttle boost deviation so fitted it in parrelel with my standard n75 f valve which is tweeked to give alittlke bit more initial boost, set the unos with stronger spring it comes on at 1.54 bar now and hold 1.2 at the red this is running 3 deg advance timing and slight fueling adjustment with a bit more pre load on the wastegate, the boost this way feels so strong compared to just running an n75 and has made the car even more responsive, i did the varios logs boost timing pull fueling egts etc and all looks good fueling is 0.830 troughout timing pull is no more than 5 egts no more than 910 on wot and boost is bang on heres a boost log to show you this is on a 25 degree day also when cooler boost timing and gs are better have seen 220gs with logs to prove
  20. #69
    Sep 2009
    Essex
    2,366
    Post Thanks / Like
    good reading in this thread, not getting a lot of time to spend on the board lately though :S
  21. #70
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Quote Originally Posted by harty190486 View Post
    I get the same issue with lower logs in higher ambient temps.
    This liquid gauge I have now has proven to be a most useful tool for this....
    Car is broken at the moment and receiving a new prop and downpipe, but once done I shall take some photos.
    The interesting thing being my requested vs actual live graph. With it being a live display of actual boost with a smaller white line to show ECU request, it makes it easy to see what's happening there.
    On the N75 valve - of any type - my actual boost never meets the requested level. Requested on full throttle is ~21.5 PSI. Actual gets to around 19 PSI tops.
    I've set my MBC to 21.5 PSI now and it achieves it with now problems. If achievable with the MBC connected - this means that it's not the fact that the turbo is tired causing this problem.
    The main difference between the MBC and N75 is the simple fact that the actuator doesn't see ANY air at all untill set boost level is achieved - this is not true with the N75 valve.
    What I think is happening here is that the actuator has gone soft on the turbo, and is being blown open long before requested boost is achieved.
    I am planning to add more preload to the actuator and then retest to prove or disprove this theory. I also have a spare K04 actuator at home which I can fit if required for testing purposes.
    I shall post results when done.
    Welly & Bumble
  22. #71
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Quote Originally Posted by s3_kev View Post
    Fiting it the wrong way round won't do it any damage -it will just give you actuator pressure at all times basically....
    Welly & Bumble
  23. #72
    s3_kev's Avatar
    Feb 2008
    1,917
    Post Thanks / Like
    yeah i noticed i was only getting actuator pressure was only about 6psi peak... just woundered if it was posible to have damaged the n75 as that is all that has been messed with between using the mbc. iam going to pick up my old n75j i sold a mate this eve to see if this helps. if not all i can put it down to is tesco's momentum99 being cack and i will go fill up with sheel again.. thought id try the momentum after your recent thread and could'nt be arsed to drive 20 odd miles to get shell at the time
  24. #73
    s3_kev's Avatar
    Feb 2008
    1,917
    Post Thanks / Like
    changed n75 over and problem solved again lol, so my n75 must be intermitantly faulty too. so i won't be blaming tesco fuel haha however i have got a full tank of sheel in her now
  25. #74
    s3dave's Avatar
    s3dave is offline mediator
    west yorks
    6,187
    Post Thanks / Like
    kev.. running my j valve makes mine run sweet and strong boost
    Quote Originally Posted by 16Klappe View Post
    And anyway, less of the thinking because I'm ALWAYS right!
  26. #75
    s3_kev's Avatar
    Feb 2008
    1,917
    Post Thanks / Like
    yeah i had it on when i had mine stage2'd but swapped back to std after and made no real difference at the time so i sold it on but got to buy it back now hahaha
  27. #76
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Post Thanks / Like
    I got a n75c and the nipple that goes into tip has been opened up(looks like its been done with a hot pin) ,makes a big differance, pulls like a train.
  28. #77
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Quote Originally Posted by Madeley View Post
    ?? Pics!
    Welly & Bumble
  29. #78
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Post Thanks / Like
    Theres no chance of a pic, it's tiny. l think it just gives the actuator more vacuum pressure, the hole is only about a mill bigger.
    If you look inside the nipple you will see the restriction.
  30. #79
    Dec 2009
    colchester essex
    320
    Post Thanks / Like
    ive just ordered a forge unos mbc last night can somebody please give me some quick instructions on how and where is the best place to fit it?
    cheers
  31. #80
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Post Thanks / Like
    Anyone had a try of one of these Awesome > ECS Race N75 Frequency Valve 1.8T
    I bet its just got a bigger hole like mine.
  32. #81
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Hmmmm, I've heard various rumours. I believe these are the N75H valve from the S4 relabelled with Awesome's logo. It's much the same as te J valve and encompasses many of the same problems. I.e limp mode caused by overboost on a standard map.
    Welly & Bumble
  33. #82
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Post Thanks / Like
    What about a J valve with a mbc fitted between the tip and n75 to tweak the boost up abit before it over boosts. only a idea..
  34. #83
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Tried that in the past - will bring on limp mode. It will over boost. End of.
    Welly & Bumble
  35. #84
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Post Thanks / Like
    Can you compare the n75c and J reducer sizes?
  36. #85
    S3 Nattie's Avatar
    S3 Nattie is offline Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Post Thanks / Like
    Ive been running a J valve for ages on a standard map and its not once put me in limp mood.
    Nathan
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
  37. #86
    Dec 2009
    colchester essex
    320
    Post Thanks / Like
    my mbc turned up today, could somebody please post up some instructions on where and how to fit it ?
    cheers danny
  38. #87
    s3dave's Avatar
    west yorks
    6,187
    Post Thanks / Like
    cheers danny
    Not been funny or anything, but as you dont know where to put it,, do you actually no the risk of fitting this?
    most that fit them on here know a thing or two of how it works....just dont want it to end in disaster for you danny....
  39. #88
    s3_kev's Avatar
    Feb 2008
    1,917
    Post Thanks / Like
    Have to agree here, seen all to many cars over my time where people who dont no what there doing make a hash of it leaving it to myself and my work mates to fix..
    i took mine off as it was no good caused over boost and limp mode anyway so unless your patient enough to set it up or can have it setup/mapped accordigly it may not be suitable anyway.
    just dont go silly with boost as you may end up bending rods
  40. #89
    Speedy Steve's Avatar
    Speedy Steve is offline 5th Gear
    Nov 2008
    Leicester
    1,133
    Post Thanks / Like
    Can i use my G/S to claim my BHP? hehe
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
  41. #90
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Quote Originally Posted by Speedy Steve View Post
    Yep, do you know the conversion equation?
    Welly & Bumble
  42. #91
    Dec 2009
    colchester essex
    320
    Post Thanks / Like
    alright guys i fitted it today after work on its own and the n75 electronically connected, before i had fitted it i was getting 1.5 bar in 5th gear and droping to 1.25
    i wound it right out and went up 2 clicks at a time till i got to 41 clicks which went into limp mode was reading 1.3 bar in 5th gear and dropping to 1.1
    so ive now wound it back 2 clicks and it is reading 1.2 bar and droping to 1 bar but it holds all the way to redline and feels just as strong as the n75 running 1.5
    Any explanations to why it feels better running less boost?
    And what triggers limp mode?
    cheers Danny
  43. #92
    s3dave's Avatar
    west yorks
    6,187
    Post Thanks / Like
    did you plug the ends of the n75?
    overboost will have caused the limp, if it deviates to far from requested boost you will hit limp.....
    you say it feels just as strong, it is better in what way ....smoother?
  44. #93
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    Firstly, what N75 valve are we talking?
    Normally the N75 will give you a good spike, and then fade away quite quickly. The reason being that the map that's on the car controls it. You can see what's going on by looking at the N75 duty cycle on a log.
    You need to understand how the N75 actually works for openers. Boost controller - Wikipedia, the free encyclopedia & What the N75 valve does... - SEAT Cupra.net - SEAT Forum.
    When trying achieve max boost the duty cycle will be at 95% - this means the N75 is effectively closed. As the boost gets close to requested, this will drop down to the 70s and then down further. This means that the valve is opening and is allowing the boost to fade away as it opens the wastegate on the turbo via the actuator.
    An MBC doesn't suffer from this. The ball and spring mechanism on the MBC will not open untill the pre set boost level is reached, and will keep this boost level for as long as the turbo can produce it. As the pressure drops because the MBC is open, the ball & spring will close the valve again, allowing boost to come back to the preset level. Good info here: Intro to Boost Control
    Limp mode, as you know is a self protective safe mode effectively. Brought on by many things, boost being one of them. The engines have a MAP (Manifold Absolute Pressure) sensor - so the ECU knows what the boost pressure in the charge system is. The ECU therefore can compare what boost it asked for, and what boost it has. If there is a difference between the two of more than 250 millibars, it will assume there is a problem and hit limp mode.
    Also - if fitting a manual boost controller, it is usually worth doing the N249 bypass. This is another way that the ECU is able to vent boost from the charge system - it opens the DV at the ECU's request.
    Even with the N249 disconnected, the ECU can still have you though. I have no N75 and no N249. This means that boost is completely beyond the ECU's control. However, being the clever little sod it is, when (and I do occasionally on the MBC) hit limp mode, it cuts the spark to the coil on cylinder 1 to stop it being driven...
    Little git.
    Welly & Bumble
  45. #94
    Dec 2009
    colchester essex
    320
    Post Thanks / Like
    Cheers for all of that juicy info its a great help, its the standard n75 that i was running.
    right ive been out for a long drive today testing.
    On the n75 as i stated on the last post it was boosting at 1.4 in 5th gear,
    now im running the MBC and can only get 1.2 untill it goes into limp mode but the dv is a lot louder and the the turbo sounds loads lauder then it did running 1.4 on the n75. which doesn't make sense, so the only thing i can come up with is
    that the turbo is actually producing 1.4+ and i have a boost leek in the inter-cooler pipe as i have relocated my dv to the cold side and my boost gauge is plumbed in to the dv vac pipe, so the pressure on the gauge would be the boost im achieving at the inlet mani hope that all made sense to you.
    Im going to change the MBC back to the n75 tomorrow and see if i still get 1.4 in 5th that should tell me if i have a leek.
    if anyone has anymore theory's please share them.
    danny
