Sky InsuranceChris Nott
Results 1 to 9 of 9
    kelk11's Avatar
    Feb 2009
    102
    snapped dipstick tube, could damage have been caused?
    on the motorway earlier the oil min light flashed up on the dis. got home to check the level of the oil to find the dipstick casing snapped clean across. i presume this is where the oil has disappeared to as its broken near the bottom? is it drivable as in to the garage?
    could any damage of been caused by any crap getting into the system through the broken pipe?
    thanks
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    No, you should be OK - this happens on a regular basis, including to me.
    Keep an eye on the oil levels after new dipstick installation, and on removal of the broken one, have a visual check around and inside the stub that it fits on to just to be safe.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Sep 2009
    Essex
    2,366
    you regularly run it low on oil welly??
    broken tube can lead to bits of plastic being dropped into the sump which end up in the oil pump pick up
    also it let un metered air into the turbot
    all in all not good
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Not what i meant dude. I meant the dipstick snapping issue happens regularly! I go to great lengths to NEVER run her low on oil. Sadly, things like dipquick snappage are just unfortunate and symptoms of age.
    Homer Simpson
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    yup same as above....just make sure that the inside collar is not stilll suck in the metal tube otherwise the new one wont fit properly
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Sep 2009
    Essex
    2,366
    i know you like danger but running low on oil is like peeing on fences to find out if theyre electric ones or not
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Matt82 View Post
    Oooooooh, just the thought of that hurts....
    Another one is sticking your finger into plug sockets to see if they're live or not....
    Homer Simpson
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Due to remove my PCV system and install an oil catch can. Want to replace the dipstick holder at the same time. There are various part numbers. Anyone know the correct one for a BAM S3?
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    all in all not good
    This is what's happened to mine, the plastic was so brittle it crumbled away like cheese. I am going to drop the sump soon.
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
