Chris NottMonster Motorsport
Results 1 to 8 of 8
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    4 wheel alignment results.
    Hi all,
    Just had a 4wheel alignment done after renewing balljoints etc...
    Does this look ok?
    Front Camber: L-0.51 R-0.50
    Caster: L6.52 R6.49
    Toe: L0.03 R0.03
    Total Toe: 0.06
    Rear Camber: L-1.38 R-1.36
    Rear Toe: L0.10 R0.09
    Thrust 0.03
    These wear after adjustments....The caster is highlighted in Red on the printout, apparently its non adjustable.
    No one from the local ProTyre could figure out why the caster was so far out?.
    Any ideas?
    Before readings
    OSF Toe was 0.45 - which would explain why my steering was pulling.
    NSR Toe was 0.35 - which im hoping was from where i had the are off to renew the bearing.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by csweatherston View Post
    Hi all,
    Does this look ok?
    Front Camber: L0.51 R0.50
    Caster: L6.52 R6.49
    Toe: L0.03 R0.03
    Total Toe: 0.06
    Thrust 0.03
    Any ideas?
    Before readings
    How does she drive now?
    Homer Simpson
    Sep 2009
    Essex
    2,366
    castor is adjustable by moving the subframe back and forward
    positive front camber sounds bad though
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    It drives beautifully.. the steering feels a lot more responsive too.
    oops, the camber is negative, ill edit the above post now.
    Just did a quick search, a lot of golfs/a3's etc show excessive caster on certain equipment?? its odd both sides are so similar unless its had a front end shunt?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Negative camber = much better
    Homer Simpson
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Was it Protyre in Bristol?
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Nope protyre in Tavistock devon, as i get trade there it only cost 35 for the whole lot.
    Wheras protyre in Plymouth wanted 24 per adjustment lol
    They use some bloody good equipment though:
    connect a plate to each wheel, then they turn the steering, shows how much every variable is out.
    even shows them where/ how to adjust it onscreen.
    I had to lol, at the young lad trying to release the four bolts holding my trailing arm on.
    He tried using a 1/4" drive at first.. then 3/8".
    I felt then was a good time to tell him i rattled them up with a 500 ftlb air gun.
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Unfortunately Audi state you cant adjust camber/caster on the front. Means its a bugger to get most places to to it.
    2003 Audi S3 + Go faster bits
