AH FabricationsVolks Autos
Results 1 to 12 of 12
    Russ's Avatar
    Jun 2009
    61
    Buggered Alternator
    Well it looks like the alternator's given up. Batteries not charging and the light's come up on the dash.
    Does anyone know where I can get a reconditioned one for a good price or if there's anything else I should check before I order it?
    Cheers all
    Having a signature for the sake of it...
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Ebay is generally a good shout mate, and most come with waranty.
    http://cgi.ebay.co.uk/RY2165-Alterna...item1c1080fca6
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Also, if you have a multi-meter, check the voltage across the battery terminals with the engine running. It should be 13 or more.
    Homer Simpson
    Bignick's Avatar
    Jul 2008
    Kent
    165
    I just changed the bushes in mine it only cost 18, job done.
    The light that burns twice as bright , burns half as long.
    Russ's Avatar
    Jun 2009
    61
    Cheers Welly, will have a look.
    Nick, did you have much trouble getting the alternator out?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Russ View Post
    It's easy mate - Slacken the belt, two bolts the remove.
    See this: http://forums.vwvortex.com/showthread.php?2553076
    Homer Simpson
    Russ's Avatar
    Jun 2009
    61
    Sod it, if I break it then I'll just pay someone to fix it. Cheers peeps
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    No problem.
    Homer Simpson
    Russ's Avatar
    Jun 2009
    61
    Ok so it's definitely the battery. Multimeter was reading 12.5v before I started the car and 12 with the appliances on and revving to 2k.
    Question now is, will a fully charged battery get me the 45 miles needed to get it to my parents where all the tools are?! :-s
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Do you means it's definitely the alternator? Charging at 12 Volts is the alternator matey, as it's not really charging at all.
    Speaking from experience, it should last you 45 miles as long as fully charged.... No electrics on!!
    Homer Simpson
    Russ's Avatar
    Jun 2009
    61
    Yeah I meant alternator hehe.
    I shall use natures air conditioning and hope I don't get stuck in traffic!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    My advice is take fuses out of systems you don't need....
    I managed 120 miles on 1 battery with a shagged alternator at night....
    Scary, was on the motorway going as fast as poss with just front fogs on.
    Homer Simpson
Tags for this Thread
