Volks AutosAH Fabrications
Results 1 to 14 of 14
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    My ongoing knock.
    Hi all,
    Im going to document this untill i find the knock.
    Basically, I drove over a cobbled road a few months ago and it sounded like all four wheels were about to fall off.
    so once home i jacked up each wheel to check for free-play/ movement.
    nothing anywhere.
    So far, replaced all four drop links, no change.
    Dogbone poly mount, no change - other than vibration on idle for a few days.
    Both front track rod ends... Again no change.
    Today i renewed front and rear ARB bushes, i dont think its cured it.... But im going to look for a cobbled road, see if its cured it.
    Also painted up the Balljoints today... so next step will be renewing the pair.
    Callum
    Sep 2009
    West london
    379
    What about changing wishbone bushes
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    I cant get any movement out of them, however they are on the list.
    A 5ft tyre lever under the bush should get some movement out of them lol
    My order will be Balljoints>Wishbone bushes>Rack ends> subframe bushes> topmounts + shocks> New car
    Chugger
    North Devon
    2,716
    sounds like shocks to me if there crashing about, no oil leaking from them?
    57 A3 2.0 TDI Sportback (140)
    Sep 2009
    Essex
    2,366
    sounds like a lot of work and wasted effort if you dont actually know the cause of the noise
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Nope, no oil around the shocks.
    It would be work and wasted effort if i never find the knock. However, all the parts so far look to have been the original items so nearly 10years old.
    Which im quite happy to replace, if they last annother 10 years.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    It's the shocks
    Jun 2010
    north west
    engine mounts if everything else is ok, they perish from inside out so may look ok
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Renewed my balljoints this morning... 54 for the pair from GSF.
    Noise has now gone, Just had my 4 wheel alignment done.. Results were a bit odd, however ill start a new thread for that.
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Matt82 View Post
    To be fair mate, I've got a knocking coming from my S3 that has been getting progressively worse for a while now - and be damned if I can figure where it's coming from.
    It's low down on the suspension though as going along at 70 MPH I can feel it through the floor pan. It's in the garage today as I can't do anything further with it without a ramp - can't really pry stuff and swing about when led on your back
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    beachbuggy's Avatar
    Surrey
    1,727
    It must be that time of year! I have exactly the same problem. Replaced all the bushes, mountings and bearings and it still knocks! Can't make it do it will stationary, jacked up or on stands, yet drive over the smallest stone or cats eye and it clatters like buggery! GOing to have to check/change the ball joints now, only thing left.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    I couldnt find anything wrong with the balljoints prior to removal, however when off the vehicle they were loose as hell.
    Dont forget to mark your arms before you renew them.
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    Quote Originally Posted by beachbuggy View Post
    Mine has got a knock too, i get it when i lift off power (had engine mounts checked, yest) & i got it tonight pulling slowly up a drive & turning. I was thinking CV / Driveshaft or Lower arms.
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
    Dazboss's Avatar
    Jul 2010
    366
    & also get it on the door (im sure thats the door bracket though... spray grease)
