Results 1 to 9 of 9
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    Chesterfield, Derbyshire, United Kingdom
    612
    Question HELP PLEASE - just fitted lowering springs ??????
    hi, ive put 30mm lowering springs on my a3 1.8t and just noticed that my top munts sit higher than they did before on both sides, before they were very nearly touching the inner wing but now there is a few inch gap. is this normal after fitting lowering springs. any help on this please
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    no, sounds like you've done something wrong.
    The top mounts, and the way they sit in the body shouldnt change at all when you change the springs.
    you simple remove the top mount and bearing from the shock, undo the top cap holding the spring, replace the spring, then just replace everything else as it came off.
    How does the car sit height wise?
    May 2010
    West Sussex
    157
    As above,they should stay the same. Mine diod on my S3 when I did them the other week.... You maybe put something back on the wrong way ?
    Ebony black 99 S3, Forge 007, cone filter, goodridge braided lines, apex lowering springs. More to come...
    Chugger
    North Devon
    2,716
    you have put the top mount assemble back together wrong. Maybe put the little cup bit in the wrong way round
    57 A3 2.0 TDI Sportback (140)
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    Hi everyone thanks for the replys but ive checked against a diagram i got off net and i same as mine. car is sitting fine, ive ordered some new bushes and bearings so see if that makes any difference. maybe the extra preasure on the old bushes as just squashed them. i don't no im just guessing lol. noticed today as well that when im turning the right hand side is making a noise. it sounds like the spring is grabbing (if you no what i mean)
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    Sep 2009
    Essex
    2,366
    doesnt look that bad tbh i expect thats due to the new angle of the damper due to being lowered
    there wont be any harm in putting new top mounts and rear wishbone bushes on... but really you want new dampers
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    Just thought i would let everyone no that i changed the bushes and bearings for the top mounts and it has sorted the problem. they are sitting properly now
