Badger5Chris Nott
Results 1 to 34 of 34
    Jul 2010
    bristol
    647
    disconnecting haldex - can it cause damage?
    ok ive just pulled the haldex fuse and took the car for a spin and it really does drive noticably better! with it working the power would die off at 5k revs and just moan to the redline (suspect it needs another remap!) but now with the fuse pulled, the car pulls very nicely!
    my question is, can i leave it like this or will it cause damage?
    thanks alot
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,413
    Define how it 'drives' better'? I guess it won't damage it with it off, you just won't have 4WD. So long as the front and rear axles are rotating at the same or similar speeds, I guess it can't damage it.
    You've got to have a laugh!
    Jul 2010
    bristol
    647
    well like i said, with the 4WD active it would just feel strangled after 5k rpm and massively bog down when pulling away, now, it actually pulls very nicely to the redline so its not just a psychological thing could this possibly indicate that somethings actually wrong with the system?? i cant seem to find any reciepts for a service of the system which is abit worrying!
    thanks for the quick reply
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    well i did have a switch in it so i could turn it off whenever i wanted to have abit of fun and ive never broke anything (touch wood) so should be ok.
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by quattro1 View Post
    thanks alot
    plus you would have to change your user name....
    Jul 2010
    bristol
    647
    haha ^^
    the switch isnt a bad idea though!! cheers for the quick replies, spot on!
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    Absolutely fine
    barters3's Avatar
    May 2008
    440
    when my haldex was faulty i did a lot of driving without 4x4, i thought it drove like a bag of poo! the front wheels would just light up off the mark.
    To be honest it has put me off ever owning a fwd car over 200bhp. (unless it had a proper lsd!)
    Does your car have an esp button. If so turn it off, this would definitely transform the car.
    Jul 2010
    bristol
    647
    nah doesnt have an esp button i do suspect its partially due to how its currently mapped, i bought it on the promise that it had been remapped prior to having a ko3s fitted, ive had doubts from the day i got it that there was any truth in it, it has flat spots and as said with the 4wd enabled it dies after 4.5-5k, doesnt give me any more than 19mpg no matter how i drive it either! ill drive it for a few days and see what actual differences it has made
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Hmmm, that doesn't sound right to me at all dude.
    It should pull the very similar in 4WD as it does in 2WD.
    Sounds to me like you have an inherent problem there somewhere, especially with the MPG you're getting.
    Have you had it read for fault codes or the like?
    Homer Simpson
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    It must be in your head, as the car is 2wd most of the time, and only 4wd when it senses you have lost traction.
    Unless you have a HUUUUGGGEEEEE turbo spooling up at 5k and breaking traction under boost, it should make no difference. It shouldn't however do any harm either
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,413
    Quote Originally Posted by Byzan A4 View Post
    It will most likely be in 4wd mode @5k revs, the Haldex kicks in on throttle position too, and at 5k revs, you are most likely on full throttle.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    there was a pdf from Haldex themselves not recommending you go over 30mph with haldex disconnected...reason being is that the parts are still moving regardless of fuse being pulled (you can also lift your handbrake one notch to disengage it)
    personally i wont ever be doing it based on what i have read in the past - google that doc if i were you
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by 1animal1 View Post
    I remember reading that now you mention it.
    Homer Simpson
    Jul 2010
    bristol
    647
    no its definately not in my head it is 100% deffo better in 2wd! the difference is too massive to be a psychological thing! i'll be plugging it back in tonight anyway as i have read the doc mentioned above and dont like the sound of it at all! guess ill just have to wait for the remap and see if that makes any difference, but serioulsy, after 5k it sucks!
    cheers for all the good replies, really helpful
    Jul 2010
    bristol
    647
    no i havent had it read for any faults, is vagcom easy enough to use? been thinking of trying it myself!
    cheers
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    Erm ya not mistaking it for the common s3 driving characteristic are ya, tails of not much more than 5k
    barters3's Avatar
    May 2008
    440
    it would definitely be advisable to have it vagcom'd before you go mapping it. as stated it tails of above 5k, i dont really feel the need to rev it passed 5k, but perhaps thats just down to my driving style?......
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    can anyone tell me where the haldex fuse is?
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    the fuse board
    Jul 2010
    bristol
    647
    number 31 if i remember rightly lol
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    or lift the handbrake 1 notch.....same effect
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    cheers
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,413
    If you have ESP.
    Sep 2009
    Mid Sussex
    162
    lol or open the boot that also switches it off for some strange reason
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    What have you read in the past and is it safe to use the handbrake to turn it off. why would you want to do that anyway?
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
  28. #27
    scoobyra's Avatar
    It's not f@cking ORANGE!!!!!
    Feb 2008
    Portsmouth
    803
    Pulling the handbrake up makes the car go into 4 wheel drive mode. Very good for launching at 5k (apparently )
    JAFFASPORT - 2001 Facelift, 218/237/216bhp AMK, Absolute Red, Thrashed to Death, Car Park Dents Everywhere, Kei Flux's, Knackered Shocks, Scuffed Rear Bumper and in need of a good Hoover!!
    BLACK EVO BEATER -2001 Facelift, 349bhp AMK, Ebony Black, Blue Seats, 4 Wheels, Brakes, Exhaust, Headlights, Sh!t loads of boost and up for sale!
    RGV 250N - Bloody fast and loads of fun........I get wet a lot when it rains....
  29. #28
    Sep 2009
    Mid Sussex
    162
    Quote Originally Posted by scoobyra View Post
    Pulling the hand brake up turns it off not on
    A3 1.8t quattro -
  30. #29
    Sep 2009
    Mid Sussex
    162
    I personally don't see why it is a problem considering when you brake it also switches off, the orange haldex controller keeps the 4 wheel drive active while breaking...
    But saying that I have also read the same thing about 30Mph thing
    A3 1.8t quattro -
  31. #30
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    803
    I'm not sure about that Dave as I read that pulling up the hand brake tricks the haldex into thinking it needs to drive all four wheels, a method we've been using for 1/4 miles for ages.
    If I turn the esp off and lunch the car at 5k the front wheels spin like mad. Pulling the hand brake up makes the car rocket forward without any wheel spin what so ever!
  32. #31
    Sep 2009
    Mid Sussex
    162
    Yep do a quick search haldex bible, search handbrake in the PDF
    The handbrake switch sends the "handbrake
    engaged" signal to the ABS control module
    J104 and simultaneously to the Haldex con-
    trol module J492.
    Whereas the ABS control module transfers
    this information to the Haldex control unit in
    filtered" form along the CAN bus, the
    Haldex control module also receives the
    information directly from the handbrake
    switch.
    if the signal generated by handbrake switch
    F9 is picked up, the Haldex coupling clutch is
    opened.
    http://www.billswebspace.com/HALDEX.pdf
    A3 1.8t quattro -
  33. #32
    Sep 2009
    Mid Sussex
    162
    What's interesting is that you turn ESP off first, maybe it's the opposite when you do that. Lol I do some testing in my car later
    A3 1.8t quattro -
  34. #33
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    i thought applying the handbrake turns 4WD off cus it doesnt want to drive the rear wheels if the brake is on
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
  35. #34
    Apr 2004
    12,500
    Quote Originally Posted by Cookstein View Post
    Correct.
