EM TuningChris Nott
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Climate Control Module Removal
    Right, first job on the new motor is to remove the handsfree kit which is being held on by something behind the climate control panel.
    Edit - climate control is right above the ashtray under the double din HU.
    What is the process for removing it?
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Anyone - im sure one has taken it out !
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Its just a case of removing the stereo, and surrounding trim's then you should be able to get to where the cradle is bolted to the dash to remove it, (did mine last week but unfortunatly slightly damaged the piano black trim that sits round the hazzard light button and cup holder)
    To remove it properly you may have to remove the glovebox to get to the handsfree master unit, (thats if the master unit has been put there!! otherwise just cut all the wires and tuck them away out of sight)
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
