AH FabricationsEM Tuning
Results 1 to 19 of 19
Thread: APY ecu
    Madeley's Avatar
    Jun 2010
    Telford
    125
    APY ecu
    Anyone got one for sale?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Spotted one on ebay yesterday... about 250 ish IIRC...
    <tuffty/>
    Madeley's Avatar
    Jun 2010
    Telford
    125
    i'll take a look, does anyone no if the amk is the same connection as the apy?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Fairly sure they are a different ECU... AMK introduced wideband lambda, VVT and a few other features... not sure if they are compatible... immo version may be different too...
    <tuffty/>
    May 2010
    BERSHIRE
    41
    pretty sure i have one im me for details
    WANTED : BLACK LEATHER REAR HEAD REST FOR S3
    Madeley's Avatar
    Jun 2010
    Telford
    125
    The problem i got is i got a amk car with a apy engine in it , ive read the two heads have the same casting, so could i just fit the vvt to my head?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Right, with you now.... APY (IIRC) has SAI so you will need to blank that, swap the VVT/cam chain tensioner over too the APY head and all should be good...
    Only other thing I would advise if you are having to strip the head to to consider getting the exhaust guides replaced... these wear very quickly and so I have been told can contribute to valve failure...
    <tuffty/>
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Is it a head off job to fit the vvt? and whats a SAI? i'm a little green with this new tec, i did my yts on morris minnors
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    VVT is part of the cam chain tensioner and can be done with the head on... ideally requires a cam chain tool (about a tenner on ebay) and careful alignment of the cams but its not that difficult... there are a few guides kicking about on places like VW Vortex (I think I have linked to it a couple of times here but god knows where) so have a google...
    Secondary Air Injection (SAI) is a system used on some 1.8t's for emissions... the AMK/BAM S3's don't use it and it will be bolted to the gearbox side of the head if still there (by the plastic water housing) or may have already been blanked off...
    <tuffty/>
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Is this all l need and it will work?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Any one got a second hand cam chain tensioner for a AMK for sale?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Madeley View Post
    No, no, no.....
    Don't get a second hand one dude. I know they are expensive, but installing a second hand one is a mistake. They never seem to work properly once they've been fitted and removed anyway to be honest.
    A new one at Audi seems to vary depending on where you go. Shop around.
    On the angine note, how have you ended up with an APY engine in an AMK car?
    Homer Simpson
    Madeley's Avatar
    Jun 2010
    Telford
    125
    350 new
    I have not had the car long and i'm finding all sorts odd things with it, like the wrong engine. its also got a screemer pipe on it, so god knows what turbo's in there!! next problem hehe.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    350 new
    A screamer pipe? OK, well it must have an external wastegate then for one to be fitted at all. So not a K04 as they are internally gated.
    Sounds interesting.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    That looks to be the right on to be fair - check the part number though.
    If I were you, I'd phone up Audi and ask them what part you need. Then get the part number and cross reference it against that item.
    Could get yourself a bargain there, they are about 300 new.
    Homer Simpson
    Jul 2010
    bristol
    647
    are u sure its a screamer pipe not just a blowy exhaust?? lol
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Dunno!! i'll get a mirror in there and have alook tommorrow. It may just have a pussy cat stuck in there.
    S3 2000 AMK car with a APY engine, minge blue, rs6 alloys and Revo'd by Badger5
    Madeley's Avatar
    Jun 2010
    Telford
    125
    small update, got that cam chain tensioner off ebay, just got to fit it, is it a easy job? do l have to split the chain?
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Put the new cam chain tensioner on yesterday, quite a easy job just a little fiddly. It feels like a new car, it now revs hard through all the gears. service, mot , tax and a remap next...yay
