Chris NottMonster Motorsport
    76
    High milage service.
    My 1.8tqs has just turned 94k so she'll be needing a service soon, whats the best grade of oil for this engine as all the books at work list 10w40 semi, and what else should i do to keep her in good condition. (water pump tensioners and belt replaced 1k ago)
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Spark plugs, filters(oil,air,fuel,pollen) oil - 5W40
    gearbox oil, rear diff, haldex
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Jul 2005
    2,488
    sump pump and strainer check and clean.
    Sep 2009
    Essex
    2,366
    pas fluid, brake fluid, coolant
    tbh... just do what needs to be done. 94k isnt a lot of mileage anyway, just carry out the servicing thats necessary if you care enough and if you really want it to be bullet proof, do the non service schedule items too
    76
    is it ok to use an engine flush before an oil change?
