Diving along this afternoon and the temp warning symbol came up on the dash, the needle went straight up to 120 and stayed there. I was on a duel carrige way at the time so i had to keep going. On with the heaters and minimal rpm, i cruised home and the temp stayed at 120!! When i opend the bonnet you could hear the engine contents boiling for about 15 mins. And then later on i checked, and about half a ltr of coolant was missing out of the expantion tank, and when i turned the ignition on it warned about temp with out even starting it. Would a diagnostic be worth doing? or will the water pump have to be removed?
I changed the thermostat about 8 months ago and the needle always stays in the center. Any help would be apreciated.
