Monster MotorsportVolks Autos
Results 1 to 9 of 9
    Jul 2010
    Birmingham
    66
    1.9 TDI Poor MPG
    hi
    i have A3 1.9 TDI 130 has 94K on the clock is doing about 120 miles on 17 liters arond town thats about 30MPG had an oil and filter change this seems quite low is my MAF sensor faulty what else can cause MPG to be low the performace is fine it is a bit smokey
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    Definitely sounds like a problem, my Passat Estate TDI 115 does around 40mpg all day long, and it's a heavier car.
    Jul 2010
    Birmingham
    66
    what do you think the problem is could it be the maf sensor
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Anil
    If you can disconnect it and drive around with it, see if it makes a difference, if it doesnt then its not that.
    See if you can get the car on VAGCOM, that will bring up any faults if there are any.
    Chugger
    North Devon
    2,716
    if there only short town journeys, alot of driving from cold thats about right.
    57 A3 2.0 TDI Sportback (140)
    Sep 2009
    Essex
    2,366
    right. check your egr is not sticking open and then check for boost leaks. those two absolutely destroy mpg on the pd lumps
    ruairi83's Avatar
    Dec 2007
    739
    MAF ,air filter and fuel filter might need changed also mate. had same problem and MAF and fuel filter Sorted it on my TDI
    Jul 2010
    Birmingham
    66
    i have got a vag com scan done came up with fuel temp sender and temp sensor power seems to be a bit flat some times might clean the EGR as its done 95 K
    thanks for the help
    Jul 2010
    Birmingham
    66
    had a new maf due to car bieng down on power also cleaned the egr its was full of crap im going to change the fuel filter as its done more than 10k miles
