Chris NottSky Insurance
    S3 Paul's Avatar
    Oct 2006
    2,764
    Which wire to use for the dimmer function on my AFR guage...
    Ive fitted an AFR gauge in the drivers side air vent but wasnt sure as to which wire i needed to splice into for the dimmer function to work ( it is reflecting on the drivers door window ) i dont mind if it is dimmed all the time but will have to move it if i cant work it out.
    The gauge does have a wire to connect to the headlight wiring to dim it when i put the lights on... Is this a live feed or earthing out?
    Does anybody know which of the wires on the head light switch will work please .
    Many thanks.
    Noggy Blue 2001 S3
    Oct 2008
    Sunny Suffolk
    69
    Hi Paul
    The blue/gray wire is your variable power and the brown is the ground, i used this guide here...http://forums.vwvortex.com/showthread.php?3003612
    on another note..i was the guy at inters with a boost problem i took it to Jabba a couple of weeks later to discover it was a duff map!!
    jabba..dabba..doood!
    Now for sale (51) S3
    PM me!
