Chris NottVolks Autos
Results 1 to 7 of 7
    paneristi232's Avatar
    79
    Interior light won't go off when I close the drivers door!?!
    Good afternoon chaps, my car has just picked up a small but very annoying problem. When you get in it and close the drivers door the display on the dash says that the door is still open, subsequently meaning the interior light will not switch itself off. It doesn't do it in the cold i.e. first thing in the morning but when the car has been in the sun for a day and is hot inside it does. Has anyone else experienced this that could point me in the right direction. I think it must be something to do with the lock because if you open the passenger door and press the latch as though it is shut the door symbol on the dash goes out where as if you do the same with the drivers door it doesn't!
    Many thanks Jamie
    AUDI S3 2002 225 BAM ABSOLUTE RED, SUPERSPRINT MAGNUM, 18" RSTT WHEELS
    jesters3's Avatar
    The Shire's
    1,516
    Very very common issue.
    Various fixes:
    1. Take door apart to replace the switch
    2. Douse the lock internals with WD40
    3. Stick a coat hanger in to get the switch latch and clean it up a bit.
    4. Give it a quality slam shut
    5. Drive for a bit to cool down the car then slam the door shut
    6. Turn off the interior light, switch off the DIS and drive as normal
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Common door switch problem... I have the same... also had it on the boot switch, took the boot lid trims off, cleaned the switch/mech with brake cleaner then sprayed wd40 in... not had a prob since..
    <tuffty/>
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    The most permenant fix i have come across is replacement, there are tweaks of bending rods, cleaning, replacing impossible to get microswitches, but it all seems to lead to the 90 replacement part to fix it
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    I suffer from same issue. Just started. Gonna replace mine when I get round to it.
    2003 Audi S3 + Go faster bits
    1.8tplym's Avatar
    Mar 2009
    Plymouth
    49
    http://www.audi-sport.net/vb/showthr...=door%20switch
    Try this first. Worked perfectly for me and i havent had any problems since
    A3 1.8T Sport - K & N Panel Filter
    79
    Thanks very much for the replies, seems to be sorted now as the interior light is going of straight away every time.
    This is exactly the reason I signed up to this forum, lots of help, plenty of opinions and little or no *****ing. Perfect.
    Thanks again J
