Monster MotorsportChris Nott
Results 1 to 39 of 39
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    LED Sidelights and Xenons
    This is just a post to show the LED's that 'CAGE' sells against xenons... they are white 4 LED bulbs in a plastic casing (believe it or not, just like a bulb!) and a bargain too at 11 a pair. I bought some other i had to modicy to fit and didnt bloody work! These are good 'uns tho!
    ...Watching you!
    Earlsfield, London
    5,087
    Re: LED Sidelights and Xenons
    ...Watching you!
    Earlsfield, London
    5,087
    ...Watching you!
    Earlsfield, London
    5,087
    Post Whore
    Jul 2004
    Southampton
    1,747
    Yewp - they are good int they Rich brought some my self - so I can confir they are a cracking deal from Cage!
    ...Watching you!
    Earlsfield, London
    5,087
    Yep... will look better when i get around to doing the facelift lights... WHENEVER THAT may be [img]/ubbthreads/images/graemlins/smirk.gif[/img] Got such a long list, its rather low down on priorities at the moment
    Post Whore
    Jul 2004
    Southampton
    1,747
    Dito, but Im sure I'll squeez them in at some point - while were on this topic of other mods....
    Off to AMD the wonderful land of Mods, Would you recomend Eibach Springs and dampers?
    If not What and where?
    imported_YOGi
    Where can i find these Rich, can i have a link/number please? They look the nuts! Are they road legal?
    Thanks YOGi
    Post Whore
    Jul 2004
    Southampton
    1,747
    Find Cage online or PM him
    imported_Rooney
    Are they easy to instal?
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    Post Whore
    Jul 2004
    Southampton
    1,747
    Piece of cake to install and it only take 5 mins max! [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    TBH it was more effort to open up the car lean down, pull the bonet catch, get out and then lift up bonnet than it was to install these babies!
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    <font color="red">WARNING!!!</font>
    Some of these bulbs come with a clear plastic "cap" which diffusses the light in such a way that it looks more like 1 bulb as opposed to the 4 seperate LEDS. I personally prefered this look, HOWEVER, when pulling the bulbs OUT (for instance, when they blow/wear out) this cap can come loose and possibly fall INTO the headlight housing. The only way to get it out is to pull the headlight apart [img]/ubbthreads/images/graemlins/crazy.gif[/img] So if you use this cap, make sure that joker's on there TIGHT [img]/ubbthreads/images/graemlins/angel.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Just a helpful hint [img]/ubbthreads/images/graemlins/wink.gif[/img]
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    ...Watching you!
    Earlsfield, London
    5,087
    No problem here drill... They are 4 separate LEDs with no diffuser luckily... but good advice none the less
    Rich
    Drill's Avatar
    928
    Well, I've seen the 4 LED ones with the cap. Matter of fact, those are the "cheap" (Figuratively of course [img]/ubbthreads/images/graemlins/crazy.gif[/img]) white ones that only lasted about 2 months [img]/ubbthreads/images/graemlins/frown.gif[/img] When I pulled them to replace them, the cap fell off into the housing [img]/ubbthreads/images/graemlins/burningmad.gif[/img] So I had to pull the damned light out to get it [img]/ubbthreads/images/graemlins/mad.gif[/img] Talk about a PITA [img]/ubbthreads/images/graemlins/smirk.gif[/img]
    May 2003
    North West
    202
    [ QUOTE ]
    [/ QUOTE ]
    [ QUOTE ]
    Drill said:
    Well, I've seen the 4 LED ones with the cap. Matter of fact, those are the "cheap" (Figuratively of course ) white ones that only lasted about 2 months
    [/ QUOTE ]
    Ive just got mine from cage and mine have the caps, does this mean i got the cheap ones [img]/ubbthreads/images/graemlins/cry.gif[/img]
    Mark
    p.s. how the hell do you remove the bulbs, 1) i cant get my hand in to grip the rear of the bulb 2) it wont budge when i get a couple of fingers around to grab it, do they twist or something?
    May 2003
    North West
    202
    Im sure someones super glued my bulbs in.
    Has anyone changed these bulbs on an S3 and still has the full use of their hands!!!!
    Will have another go tomorrow, do the holders just pull out or twist?
    Mark
    Post Whore
    Jul 2004
    Southampton
    1,747
    They are fewkers to get out, especialy the drivers side for some reason... Pliers did the trick for me, dont crush them though!
    Cage's Avatar
    Oct 2004
    95
    PM sent MikeyD
    nervus's Avatar
    Apr 2004
    1,116
    Same here cage, i also have a 2003 S3, can you pm me details of how to pay etc. i would also prefer the ones without the caps if you can [img]/ubbthreads/images/graemlins/grin.gif[/img]
    L1ARR's Avatar
    Sep 2003
    Home Sweet Home
    360
    Cage sent you a pm and Payment can you also send me the bulbs with no caps as I also have a 2003 S3.
    Dicky Boy
    Drill's Avatar
    928
    [ QUOTE ]
    NWMark said:
    [ QUOTE ]
    [/ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    Mark
    [/ QUOTE ]
    Mark, I doubt they're the same brand I picked up locally here in Germany dude [img]/ubbthreads/images/graemlins/grin.gif[/img] So I can't testify to the quality, just wanted to be sure folks were warned about them damned Caps [img]/ubbthreads/images/graemlins/lol.gif[/img]
    Nov 2004
    Hosrham, West Sussex
    390
    [ QUOTE ]
    Cage said:
    [ QUOTE ]
    [/ QUOTE ]
    PM sent [img]/ubbthreads/images/graemlins/wink.gif[/img]
    [/ QUOTE ]
    Cage, did you get my pm last week? Still no sign of my LEDs.
    Ta,
    Adam
    Cage's Avatar
    Oct 2004
    95
    PM sent
    LED's were posted last week Friday.
    OILBURNER: Still awaiting a reply to my PM also.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    I'm thinking about these now too looking at the pics.
    Think the sidelights will look so much better next to the xenons now with these!
    How long are they expected to last and iv'e heard about some problems with the DIS flashing up warnings when they have been fitted, is there any truth in this?
    Jan 2005
    Greece
    34
    can you inform us ignorant about the xenon and the sidelights you are talking about?
    any pics etc?
    thanks
  28. #27
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    The xenons are the main lights you have on when you are driving, you will have seen them on other cars, much brighter and the light looks really blue.
    The sidelights are "position" lamps and not the bright ones you use to drive in the dark. These bulbs that Cage is selling makes the sidelights look alot similar to the xenon lights already on the car.
    I think ritch posted some pics on page 1 of this topic.
  29. #28
    RAPS3's Avatar
    Moo Moo Land
    1,040
    Fancy some of these too.
    Cage you have PM
  30. #29
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Iv'e ordered some too Paul, we will have to make the next north east meet at night so we can show them off!!
    Talking about that when are we going to organise the next one for??
    It was nearly a year ago when we had the first when we all went karting!
  31. #30
    Jan 2004
    24
    Hi Cage.
    Would also like a set of these sidelight, have PM'd a couple of times but PC is awful and it may not be sending thru...
    Ant
  32. #31
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    I bought some 4 LED side light bulbs from UltraLED's quite a while ago. I have just got round to fitting them to my S3 this morning.
    It took bloody ages. My fingers are killing me. It took real faith in removing the bulb holders - by gripping the wires and giving them a firm tug. I tried to be gentle at first, with gradual force, but they just wouldn't budge. A firm tug is the technique. [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Anyway, took load of pics, so will post them if I remember.
    Also had "fun" today fitting Philips "Power 2 Night H7 GT-150" bulbs to my girlfriends Golf Gti Anniversary. What a nightmare!! Look good though. Just judging them in the daylight (dull and overcast) the light looks much whiter. They are supposed to have a blue tint too, but I expect thats only noticable at night.
    AL
  33. #32
    AL_B's Avatar
    1,564
    Here are some pics of my 4 LED ones. These are just pure white LED's, but give of a significantly noticeable blue/purple tint - not sure if I like it.
    Also, not sure if they give of as much light as the normal bulb. Either that or the lense isn't able to reflect the light out like it can with the standard bulbs.
    The following pics are on a dull day. Will do some night-time shots one day this week.
  34. #33
    AL_B's Avatar
    1,564
    DavidR's Avatar
    Scotland
    1,295
    Much the same as mine Al.
    Not a lot of light, mostly blue although white leds??
  36. #35
    AL_B's Avatar
    1,564
    AL_B's Avatar
    1,564
    AL_B's Avatar
    1,564
    AL_B's Avatar
    1,564
    6
  40. #39
    Andy101's Avatar
    Nov 2004
    North Yorks
    166
    Guys, I've recently tried some LED's in a 2004 A4 TDi, but unfortunately they flash on and off and are not constant. Has anyone else had this problem?
