Monster MotorsportVolks Autos
Results 1 to 8 of 8
    S3PEG's Avatar
    Bristol
    99
    dumpvalve noise appeared from nowhere
    Recently had an accident which damaged the turbo's intercooler. It has been replaced and now it sounds like it has an induction kit and dumpvalve fitted... what have they done?!
    I know some people like the sound, but I really don't and want it to go away!!!!
    S3Peg
    Black S3, APR Chip, EBC Brakes, 18" RSTT's.
    Sep 2009
    Essex
    2,366
    take it back to whoever "fixed" it tbh
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    One of the side mounted intercoolers?...
    Is the car running OK? very tricky to diagnose without hearing or a little more info but I would check for loose boost hoses and look at the TIP (turbo inlet pipe) as if this is split or has come away from the turbo this could be giving the noise you describe...
    <tuffty/>
    S3PEG's Avatar
    Bristol
    99
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Not running well at all... hunting and running lumpy. The repair centre have "checked" for split hoses and claim all is well. Going to a specialist on Thursday for a proper check!
    S3Peg
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by S3PEG View Post
    I would guess that the little pipe out of the right hand side of the air box has been removed/come loose or something like that.
    You only get that sort of noise from the air box area - since that's where the diverter valve puts the diverted boost.
    Although hunting and running lumpy certainly sounds like a boost leak.
    Was it a brand new intercooler they fitted?
    Homer Simpson
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    the ducting that feeds air to the engine from the airbox has a jubilee clip, might be worth checking its tight enough. Didnt do it up properly one time and it was very lumpy !
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Who you seeing? Badger 5 is not far up the road from you off J13 M5
    <tuffty/>
    S3PEG's Avatar
    Bristol
    99
    Is "that little pipe" accessible from under the bonnet or is it in the front wing? Yes, it was a brand new, genuine intercooler.
    Thanks.
    S3Peg
