EM TuningJMB Retrofits
    S3 D2HTY's Avatar
    Apr 2010
    121
    What pipe is this?
    While taking my SMIC off the metel boost pipe that running between them. There was a metal pipe that ran from passenger side to 3/4 of the way across the car only to return back to a pipe below where it started
    Can anoyone help? What pipe it is? Also can i just do a U bend right at the start off the pipe?
    Sep 2009
    Essex
    2,366
    gonna need pics for this one tbh
    Ross_S4
    Aug 2009
    Dundee
    718
    sounds like the power steering cooling loop possibly?
    It's all in bits
    Apr 2006
    Bristol
    219
    It is a cooling pipe so if you reduce the length it won't cool as efficiently.
    By the way I'm pretty sure that the metal boost pipe you have removed (which the cooling pipe is attached to) is also for structural rigidity. A3s without twin intercoolers have a version without a 'pipe' so I wouldn't remove that unless replacing it with a non piped version from an A3.
