Chris NottVolks Autos
Results 1 to 14 of 14
    Jun 2010
    Stalybridge
    89
    Changing bulbs in facelift headlights fitted with xenons!
    Is this a bumper off job as audi say it is???
    I need to fit 2x led sidelight bulbs, 2x main beam bulbs and 2x clear indicators asap!
    Anyone willing to help???
    Maybe to fit a cupra r splitter at same time too ;o)
    52 Nogaro Blue S3 225-Revo S1-Forge 007p-18" Genuine RSTTs-Falken FK452-Autostyle Mats-Bosch Aero wipers
    NEXT-Powdercoating wheels-H&R Spacers-Neuspeed CAI-Pipeworx exhaust-MC JL Sub/Alpine Amp, Dewipered, A total bodywork makeover before its sold!
    devan's Avatar
    Jun 2010
    118
    As far as i know it is a bumper off job. Ive now changed my sidelights twice (due to one bulb failing), and both times i took the bumper off. Its not a big job though...
    5 screws around each wheel arch, 4 clips on top of the bumper, and 2 screws underneath the car... Then to save you disconnecting the headlamp washer jets and fog lights, you can just lay your bumper on some foam/rags on the floor.
    Then just 3 torx screws to get each headlamp out far enough to get your hands in.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Changing the d2s xenons and sidelights isn't a bumper off job
    Jun 2010
    Stalybridge
    89
    Quote Originally Posted by sandip View Post
    Explain clever arse!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Did mine this week, ny lights are the pre-facelift one's and tbh, itd impossible to change them with out the bumper off.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,455
    I to have manage to sort that out also
    My lights arn't bolted to the wing now so all you have to do is remove the top two screws and then pull it from the chuckle joint at the bottom
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    devan's Avatar
    Jun 2010
    118
    Thats a good idea to not screw them to the wing... should of really done that, but hopefully that'll be the last time i have to change any more bulbs for a while.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by gaznogaro2003 View Post
    Quite easy really, it's just a case of removing the black plastic cover on the back of the headlights, unplugging the plug, twist the bulb out, pop the new bulb in, plug back in, plastic cover back on, done
    The passenger side bulb will is a bit more difficult, you have to slacken off the battery to move it out of the way a little then you can do the same to that side. If you struggle pm me and i'll do it for you lol
    jesters3's Avatar
    The Shire's
    1,516
    To remove the bumper check out this linky
    To replace the side and main lights you can do as sandip says - however for the indicators I believe it is
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Help please guys.
    My drivers side xenon bulb has just blown but I cant work out how to remove it! I've removed the plastic cover from the back of the light and unscrewed the connector to the back of the bulb but I cant work out how to get the actual bulb out! Any help would be greatly appreciated.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,264
    Anyone? I need to get this out today if possible.
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Once you've twisted the connector and unplugged it from the bulb it should pull out from what i can remember
    Westy's Avatar
    Dec 2008
    17,264
    Cheer boss I've got it out. You have to twist the outer plastic fitting with the bulb.
    S3 Build Thread
    Jun 2010
    Stalybridge
    89
    Sandip !!!
    I need two led side lights fitting asap before the 12th october for the mot!
    Can we meet up soon?
    Gaz
