JMB RetrofitsChris Nott
Results 1 to 22 of 22
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Fuel System Too Lean - Bank 1 and Cylinder 3 misfire.
    My car's been acting up with a misfire.
    I've changed the coilpack for a brand new one, and cleaned the MAF this morning, but I'm still getting an error with Vag-Com saying bank 1 fuel system too lean, and that cylinder 3 is still misfiring.
    The car's down on power and running rough. What could it be? I was told it could be the spark plugs have been fouled from the misfire and also to change the leads.
    Any other ideas?
    '02 A3 TDI quattro sport
    8L IS DE BEST
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Changed spark plugs, cleaned the thottlebody and MAF. Still same problem.
    Thinking it could be the HT lead but I've also heard it could be lambda sensor, but I don't see why this would give me a misfire on cylinder 3 only. Any thoughts, anyone?
    8L IS DE BEST
    RIP S3dave
    May 2004
    nr Glos
    7,183
    what airflow does it log
    maf under reading also causes apparent lean condition
    block 032 will be +25% i guess
    what figures do you have?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Thanks for the reply.
    What's the best way to log airflow? Just drive about logging the MAF readings?
    The thing is, as it's only cylinder 3 misfiring, would it be something like the MAF as surely that would make all cylinders misfire?
    8L IS DE BEST
    hharry100's Avatar
    Feb 2007
    west london
    52
    Hey aaron It sounds like you may have a clogged/fault injector, this is the same problem i had and i bought a new bosch injector from euro***parts dont forget you should also change the seals when you remove the injector rail, i think the seals are only available from audi.
    Dolphin grey 03
    Gmbh handling pack
    Defcon 2
    H&R roll bars
    RNS-E (dvd, Digital tv tunner)
    Custom Code
    Porsche Brake set-up
    Dieselgeek stigma short shift
    *NEW* 8P s3 FBMFSW
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Thanks for the reply Harry. I'll have to check if it's a fuel injector, but I've done a log in third gear up to pretty much the redline that could perhaps rule something out.
    8L IS DE BEST
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Bill your last post isn't coming up on my phone, would you mind posting it again?
    8L IS DE BEST
    fran-s3's Avatar
    1,090
    have you considered the fuel pump may be on it's way out? when mine was doing this the engine bay was roasting to. (more than usual)
    big_mo's Avatar
    MOSES
    Nov 2007
    A great place called high wycombe, bucks
    137
    I also have the same.... bank 1 fuel system too lean. I have been to my mate and changed the air maf is well as cheacked all hoses. Still no joy
    1.8t,AUM,Ming blue,Forge TIP,Forge silicone turbo hoses,BMC CDA,Forge 007p,Neuspeed short shift gearlink,powerflow hidden cat back,miltek downpipe,R8 oil cap,HIDs,Custom Code stage 1,de badged,de wipered,FKcoilovers
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    The thing is, if it were the fuel pump surely it wouldn't affect just a single cylinder? It's only cyl. 3 that's the problem, so I guess it could be the HT lead or injector, which are the next things for me to try. The MAF readings seem ok, and surely that would affect all cylinders as opposed to one. I've changed the plugs and coilpack, so that's no worry either.
    8L IS DE BEST
    fran-s3's Avatar
    1,090
    True it effected all my cylinders! Ok cool well it's not that then lol. Yeah HT leads coil pack or spark plug would be my next bet...
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Finally got a set of HT leads after ECP 'lost' them in the warehouse. Turned out it was the leads, which is nice as an injector from ECP or Audi was about 120.
    Thanks for the help everyone :D
    8L IS DE BEST
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    sorry to bring this up again as it has now gone down the list-
    Conversely, I get "system too rich bank 1" fault codes every month or so. Anybody any idea what this could be...?
    JimP
    big_mo's Avatar
    MOSES
    Nov 2007
    137
    I have the same problem mate.
    Changed the air maf and cleaned the throttle body and realigned it deleted the code. Lasted a week till it poped up as i was going down the M40 at 80mph.
    Back to the drawing bored for me.
    Some one told me maybe a lambda probe
    Sep 2009
    Essex
    2,366
    do you have a misfire with that too?
    big_mo's Avatar
    MOSES
    Nov 2007
    137
    No i only get bank 1 fuel system too lean
    No misfire
    Sep 2009
    Essex
    2,366
    bank one is lambda 1. its trying to lean the mixture and cannot lean it any further
    basically the exaust is too rich... i think you have a boost leak richening up your mixture
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    Thanks Matt82,
    where should we look for that...?
    JimP
    Sep 2009
    Essex
    2,366
    almost any boost leak will have oil/gunge sprayed out from the leak
    prime suspect is the breather hose under the inlet manifold
    second id look at the connections into and out of the intercooler
    then around the compressor side of the dv.
    anywhere that sees boost really.
    lots to check tbh
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    Thanks for that- I'll have a look tonight.
    JimP
    RIP S3dave
    May 2004
    nr Glos
    7,183
    can you get it logged?
    cleaning a tired MAF rarely rejuvinates it
    a low g/s reading would confirm whilst logging.
    i would get this done first before you spend hours chasing other things where this is the most common cause
    www.badger5.biz
    bill@badger5.co.uk
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Whats happening on this site? loads of old posts coming up??
    EDIT: just read spammer.....
