AudiS3-Turbo
had this fault for a while now,basicly if your in a high gear say third,plate your foot on the throttle it will shoot off and you will see around 20psi(revo mapped) and then very quickly drop down to 10psi and remain like that untill you slow down...
It will hold around 18psi of boost if you nail it hard from the 1st gear onwards,its this high gear loosing boost is doing my head in.
So far its had new Maf and N75 valve,the 249 is deleted and my forge is direct to manifold and has a yellow spring so should hold the boost.
The wastegate opens around 5-7psi and i can not find any leaks as it would not hold boost when you nail it from firts.
No fault codes etc...
throw some ides my way please
