Chris NottMonster Motorsport
    Sep 2008
    29
    Bulb Replacement
    This might sound a but silly, but how do you change a headlight bulb?
    I had a look this morning and cant figure out how to get at them....
    Jul 2008
    216
    The light cover is held on by a metal clip, suction and a locating slot.
    Remove the metal clip and slightly lift the inner edge ( part closest to the middle of car) then slid/pull the cover to the middle of the car. It is a tight fit but it will come off.
    Getting it back on is far harder! place it in the locating slot before you try to fit it fully back on the light.
    Make sure the seal in the lid is in place and complete. If you feel it will help smear with a little vaseline or something as the seal will have compressed and creating a good seal to stop the light getting misty with condensation or moisture is important.
    Sep 2008
    29
    thanks dude, sussed it out, i just took the whole unit out and changed it that way
    Mar 2010
    10
    Make sure the bulb is straight. It's very easy to seat them incorrectly. Our car manage to fail the NCT (Irish MOT) becuase of this. It's easier to check through the lens.
