This is the procedure for an oil filter and oil change including the service light reset for a "long life service".
If you don't want to take it to a dealer and intend keeping the car, the reset tool is good value for money, and a simple job
You need to remove the bonnet and remove the undertray
Remove the engine cover to access the oil filter cartridge cover
Undo the filter cap and extract the filter
Try to fit a filter that is genuine as the layers of perforations will be the same as the dirty one (genuine filter). Not like the aftermarket one shown (clean filter) as it may be different and therefore the level of filtration could be less, especially crucial on long life service intervals.
This is the correct filter for Audi
Undo sump plug and drain in the normal manner
Refitting is the reverse as they say in the Haynes manual.
Making sure the new filter is in place and the plastic lid is hand tight, the sump plug is tight and a new sump plug washer is fitted if required
The reset tool is a Sealey VS862
You simply plug it in under the drivers steering column and follow the simple instructions in the booklet or onscreen prompts.
It doesn’t take this long unless you are taking photos!!
I hope this helps
Cheers Unkle
LinkBack URL
About LinkBacks
