Badger5Volks Autos
    Stuart35205's Avatar
    Apr 2013
    Telford
    108
    Fitting 195/55/15
    Hi , is anyone running these on the standard alloys ? Does anyone know if they will fit width wise etc? Currently running 175/50/15 but there quite a harsh ride! Regards Stuart
    2000 A3 1.8t sport AUM
    18 BBS LM , coilovers , strut brace , poly bushed f/end , S3 front discs , S3 rear lights , wrapped roof , face lift front lights , Forge tip , cone filter & heat shield , forge 007 DV , DV relocation kit , n249 bypass , n112 removal, SAI removal , scorpion back box , ECS shallow sump , ECS single mass clutch conversion.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Sizes
    OE tyre sizes are underlined. These, along with 155/65R15 and 165/65R15 are the only tyres that are truly 100% compatible and listed in the CoC document.
    15"
    155/70
    165/65
    175/55
    175/60 (reference size)
    185/55
    185/60
    195/50
    195/55 - identical rolling circumference to 205/40R17
    205/50
    205/55
    225/50
    16"
    175/50
    175/55
    185/50
    195/45
    195/50
    205/45
    215/40
    215/45
    225/40
    17"
    195/45
    205/40
    205/45 - this may work, it may catch. Check!
    215/40 - as above, especially at the rear
    215/35
    225/35
    245/35
    18"
    205/35
    215/35
    225/35
    225/30
    If it's not on the list, it will not fit without work / rubbing: this includes 205/55R16, 195/65R15 and 225/45R17. Do not buy it without your eyes wide open.
    Apr 2013
    Telford
    108
    Hi Craig I have read that article before , cheers I was just wondering if the had been tried & if so did they improve comfort as we all know these cars are exceptionally firm!
    Regards Stuart
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    General rule is thicker the rim, the better the ride so if you can add 5mm to the wall then it will be slightly better, but you also increase the tire width which will incur a fuel penalty as your rolling resistance will increase slightly.
    I noticed a drop in fuel economy and acceleration when I went from 16 to 17" wheels as I increased the weight and rolling resistance.
    Apr 2013
    Telford
    108
    I had heard many comments on the 17 inch wheels making the ride firmer but they do look good tho. I will have a look in to it abit more it would be interesting to know if they will fit on the standard 15" alloys due to their width ?
  1. Would a tt CD player (8J0 035 195 D) fit b6 a4
    By kevlil in forum In-Car Entertainment
    Last Post: 16th April 2013, 07:26
  2. will these fit in my trunk?
    By bethishott in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th June 2003, 21:46
  3. Help with fitting SYMPHONY double-din head unit
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2003, 21:29
  4. Has anyone fitted MTM clutch?
    By theodore_p in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2003, 12:12
