Volks AutosBadger5
    Perry's Avatar
    Feb 2012
    Rickmansworth
    50
    central locking not working from remote or from key
    As the title says really - neighbour leaves her car unlocked as only the drivers door locks from the key and remote locking not working.
    Could this be a fuse or is it more likely to be the motor ?
    Found the fuse panel on drivers side but she doesn't have the cover so struggling to know what one to look at.
    Any help much appreciated.
    Aug 2010
    1,540
    does the central locking button on the drivers door panel not work either? electric windows work? does the interior light work?
    Perry's Avatar
    Feb 2012
    Rickmansworth
    50
    Interior lights work when I switched them can't remember if came on when opened door - infact thinking about it no I don't think they did and I tried the switch on the drivers door but to avail. Didn't try the windows.
    Aug 2010
    1,540
    everything works thru the central modual to do with the windows, central locking, remote alarm, interior lights. each of the door ecus talk to this central modual.
    this ecu is under the passengers front floor and is known for faults!
    have you had the comfort 46 system scanned for faults?
    wallace78's Avatar
    Mar 2012
    belfast
    146
    hi my keys arnt locking mine remotely either is there anything i can do 2 correct this,sorry for hijacking ur threaD
    Dec 2011
    62
    there's a fulat with the control module located in the pass footwell, gets damp in there which can cause prob's but best to get it scanned forst to find out exact fault, than guessing and wasint money on parts you dont need to replace
  1. Remote central locking key remote range
    By ms1083 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2012, 19:55
  2. key problem and remote central locking
    By cwuk2001 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th April 2011, 09:38
  3. Remote Central Locking Not Working????
    By AWDMk1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2010, 12:21
  4. Remote central locking not working?
    By PiloTT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd November 2009, 17:41
  5. convert central locking to remote key
    By axelfols in forum General Technical / How To
    Last Post: 26th June 2008, 15:52
