Volks AutosChris Nott
    Dec 2012
    44
    Speedo and Rev Counter backlight?
    Hi All,
    This might sound like a rather dumb question but, Should the Speedo and Rev Counter be backlit when you set your lights in the off position?
    I have the light sensor on my car so I have the option of Off / Auto / Side Lights / On (then I can put front and back fogs on when in the On position)
    I only ask because in all my previous cars, my Honda Civic Type R for example the rev counter was always well lit. In other cars the dashboard lights would change brightness depending on if I had my headlights on or off (I forget if they got a little dimmer with them on or brighter). But never the less the speedo and rev counter would always be back light regardless of the lights being on or off.
    Now I have a little control by the light controls that I can spin to supposidly adjust the lighting to the dashboard but i've sat there fiddling with that and none of the lights appear to be getting any brighter or dimmer.
    Is this the correct behaviour with the dial and the dim rev counter and speedo? or am I the one being Dim?
    pns2007's Avatar
    Nov 2008
    626
    I think it's a safety feature that is supposed to remind you to turn your lights on. i.e if its dark the instrument cluster is dim. You'll notice when it's light outside the instrument cluster is lit. In one of my older Audi's this could be changed with VCD's (it was called needles and pins). The newer Audi's don't appear to be changed this way.
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    Dec 2012
    44
    Ahh thank you Now you've said that it does make sense. The dim instrument cluster does do the trick by making me pop the car lights onto anything other than off. I only really noticed when its been light outside but perhaps a little overcast but still perfect light in my opinion and no one else on the road has their lights on. Yet my auto lights felt the need to come on, but as soon as I switched them off my instrument cluster I would be dim and so then begrudingly put it back to auto.
    While I might not necessarily like that or agree with it at all times when it feels its too dark outside. I have to say in fairness it makes sense as a good safety feature because in my old Honda I did once forget to put my lights on when initially pulling off due to the instrument panel always being so bright.
    Hmm I bet the new A3 probably has the same safety feature too... #
    Thank you again for your reply
  1. Rev counter/Speedo fault and trouble codes to boot!
    By Dizz in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2013, 22:39
  2. Replies: 0
    Last Post: 29th November 2011, 20:30
  3. Rising and falling rev counter needle on idle
    By northern monkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2010, 10:13
  4. 2.0TDI Rev Counter, Startup and running issues......Bluefin?
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st January 2010, 21:38
  5. Replies: 4
    Last Post: 9th June 2009, 13:42
