    Aug 2011
    Oil filter location?
    Hi all,
    Quick question, can anyone tell me where the oil filter is located on the 1.6tdi A1 Sportback (2012).
    Jun 2011
    Great Melton Norfolk
    1,348
    Have a look in your handbook.
    Sure someone more knowledgeable than me will be along to give you a definitive answer.
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Here's an image from Audi, apparently of a 1.6TDI as fitted to the A1 Sportback (I would imagine largely the same throughout the range).
    As you look at it, you can see a fairly featureless shiny box pretty much slap-bang in the middle of the image (due east of the alternator). As far as I can work out, that's the oil cooler, which is attached to the base of the filter bracket - certainly there's a cylindrical unit visible behind it, which I'd suggest is a good candidate for being the filter bracket. It should just unscrew at the top, allowing you to pull the filter insert out (of course with a suitable amount of swearing due to it being the insert type, and drenched in oil! ).
    Hope that's useful; all the best,
    Rob.
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
  1. 2.5 TDI Oil Filter Location
    By mubzy79 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2012, 18:32
  2. A3 1.8T oil filter location
    By Datsun in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2012, 14:25
  3. Urgent please!Oil filter location.
    By Carli in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2010, 15:36
  4. Oil filter location
    Last Post: 5th January 2010, 21:06
  5. Oil filter location
    By Wilkinson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2008, 19:38
